Re: EMC 2013 470 B stroker build
[Re: RAMM]
#1518970
10/19/13 09:19 AM
10/19/13 09:19 AM
Posts: 1,051 The Great White North
RAMM
Here's a shot of the engine that never made it. It featured MPI, crank trigger, Victor heads, ultra light internals etc.... J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1518971
10/19/13 09:47 AM
10/19/13 09:47 AM
RAMM
Somebody asked to see a dyno sheet from UNOH. This was the very last pull. Wish we could've made 2 or 3 more. J.Rob
[Re: RAMM]
#1518972
10/19/13 01:28 PM
10/19/13 01:28 PM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Are you limited on what ring pac goes into each engine?
[Re: B3RE]
#1518973
10/19/13 02:41 PM
10/19/13 02:41 PM
BradH
... One question, what do you consider optimum adjuster angle?
Once again, two schools of thought: 1. Maintain same range of angle change in the relationship between the pushrod & the adjusting screw from min to max lift (e.g. 15 degrees "under" to 15 degrees "over") to put them both on parallel planes at the mid-lift. IIRC, that's Miller's design.
2. Start out w/ the most out-of-parallel condition when the valve is closed and have them both on parallel planes at the peak lift where the highest spring loading is. From some of what I've seen, this might be what Jesel is attempting, but I can't say for sure.
Without going into all sorts of different types of specific measurements (impact on peak lift, impact on area under lift curve, stresses on adjusting screws & pushrods, etc.), I really can't say which is mechanically "ideal".
[Re: RAMM]
#1518975
10/19/13 03:48 PM
10/19/13 03:48 PM
Posts: 4,255 Canada
WO23Coronet
Canada
What do you think that beast would've made? Also how big is it?
[Re: BradH]
#1518977
10/20/13 02:54 PM
10/20/13 02:54 PM
Posts: 561 USA
B3RE
USA
My thinking is that the more angle the adjuster is on, the side loading forces are increased exponentially. Add to that that the pushrod is literally trying to shove the rocker body into the shaft and lift the shaft off of the head as the lifter starts up the opening ramps on the cam. I would think that would create more load on the adjuster than what would be present by splitting the sweep angle between over and under the parallel plane. Don't forget about the additional harmonics incuced by the increased lateral movement of the pushrod. Think pole vault.
Hmmmmmmm!
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: RAMM]
#1518980
10/20/13 09:41 PM
10/20/13 09:41 PM
RAMM
Anyone interested in some IN-CELL dyno footage at the EMC? J.Rob
[Re: RAMM]
#1518982
10/21/13 10:53 AM
10/21/13 10:53 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Does a Shark $hit in the ocean ?
Yes, we want some dyno clips !!!
Ron
