Re: My heap got videoed @ Cruisin the Coast!
[Re: SB412DUSTER]
#1516472
10/21/13 02:12 AM
10/21/13 02:12 AM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
That is one bad a$$ hot rod you have there sir!! Be proud it is a killer piece.
[Re: 67HEMI]
#1516473
10/22/13 10:17 AM
10/22/13 10:17 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I have the TTI 2.25" primary 4" collector headers on my cuda and run the CSR shield.
[Re: an8sec70cuda]
#1516474
10/22/13 10:36 PM
10/22/13 10:36 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Thanks Al! Coming from you that is a big compliment! Your cars always are top notch! Chip has yours got the stock floor pans and If so what did you do with the drivers side bracket that holds the shield strap off of the shift cable?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#1516476
10/23/13 09:50 AM
10/23/13 09:50 AM
an8sec70cuda
Stock floor pans...the whole car is stock, lol. I don't use that bracket. I believe I just routed the strap a little farther towards the back of the trans. I'd need to crawl underneath it and look to be sure.
