Mounting lexan....
#1515324
10/11/13 06:54 AM
10/11/13 06:54 AM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Screws or pop rivets? Thanks!
Re: Mounting lexan....
[Re: slantzilla]
#1515325
10/11/13 07:01 AM
10/11/13 07:01 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I used counter sunk allen bolts and beveled the holes in the lexan and used nyloc nuts to be able to pull the front and rear windows up against a foam seal with very little tension or distortion of the lexan. this kept mine from cracking. Same for the side windows, for convenience.
[Re: cudadon]
#1515328
10/11/13 12:53 PM
10/11/13 12:53 PM
slantzilla
Park Forest, IL
Thanks guys! I like the countersunk bolt idea, but I'm afraid there are some area I can't get to the backside to put nuts on. I have some nice stainless screws with large round heads that just might do the trick. It will look a lot nicer than the hex head sheet metal screws that were in there.
[Re: Challenger 1]
#1515330
10/11/13 01:23 PM
10/11/13 01:23 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
Duck tape and elmers glue! I have always used the counter sunk screws. And a very big yes to leaving them a little loose as to not crack the lexan.
Back in the swing of things at Painless again! Great to be back!
