Flow numbers for 440 ez-1?? #1514587
10/09/13 06:29 PM
10/09/13 06:29 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anyone have flow numbers for 440 ez-1 We are going to have ours worked over and was wondering what to expect. Thanks
Re: Flow numbers for 440-1 ez?? [Re: bobs69] #1514588
10/09/13 09:08 PM
10/09/13 09:08 PM
Anyone have flow numbers for 440-1 ez We are going to have ours worked over and was wondering what to expect. Thanks
I don't think Indy makes a 440-1 EZ, I think they make the EZ in several different intake port sizes and then the 440-1
Re: Flow numbers for 440-1 ez?? [Re: Cab_Burge] #1514589
10/09/13 10:31 PM
10/09/13 10:31 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Got my ez's and ones mixed up
Re: Flow numbers for 440-1 ez?? [Re: bobs69] #1514590
10/09/13 10:40 PM
10/09/13 10:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Flow numbers for 440 ez-1?? [Re: bobs69] #1514591
10/09/13 10:41 PM
10/09/13 10:41 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Check the Tech & Best Of forum for Indy head data posted by "fast68plymouth"...
Re: Flow numbers for 440-1 ez?? [Re: bobs69] #1514592
10/10/13 10:57 AM
10/10/13 10:57 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have a set of EZ-1. They were new in '06. IIRC, the -1 is to indicate the Max Wedge size porting upgrade from the standard EZ. They show up in the link Pburg racer posted.
If you like drag racing, support your local track.
