Key left in run position 03 300m will it flood?
#1512111
10/04/13 12:41 AM
10/04/13 12:41 AM
Posts: 5,669 South Dakota
hotairballoonpilot
South Dakota
Ok kids this afternoon shut car off but then my daughter turned key back on but left it in the run/start position while my wife was in friends car talking in the parking lot which was maybe 10 minutes. She tried to start it but it wouldn't start. I tried it about 11/2 hours later same thing. Acted like it could barely turn over but not like it was dead. I tried it about 1 1/2 hours later held foot to floor. It turned over but kinda like it wanted to start but kept turning over til it finally fired off. Both times to me it acted like a car is flooded. So if key is left in the run position would or could it be pumping gas into cylinders? Seems like once it cleared itself out it was fine. Drove it home 15 miles no problems. Never acted like the battery was weak were it couldn't turn it over. Any ideas?
Contact Me about AMD Prices
Re: Key left in run position 03 300m will it flood?
[Re: Twostick]
#1512115
10/04/13 09:16 AM
10/04/13 09:16 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
shouldn't flood, but does not mean that something isn't working correctly and allowed it to flood.
If an injector is leaking, all the fuel pressure that builds when the pump primes could bleed off and pool in the intake, which could cause it to act flooded when starting.
**Photobucket sucks**
