Re: thermoquad 9810S
[Re: plumcuda]
#1510716
10/01/13 04:07 PM
10/01/13 04:07 PM
dogdays
Sure they did. Here's a quote I found after 35 seconds Google searching: "The aftermarket 9000 series were available in 4 models: 9801, 9811, 9800, 9810. The 9801, 9811 have Chrysler linkage (9801/9811 is EGR capable). Note: later OEM TQs model number started with a 9 as well, but are not to be confused with the aftermarket 9000 series."
R.
[Re: dogdays]
#1510717
10/01/13 05:01 PM
10/01/13 05:01 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
And more.
9800 9000 series, GM 4095 5137 2110 1-3/8 5 9801 9000 series, Chrysler 4095 5125 2110 1-3/8 5 9810 9000 series, GM, EGR 4095 5137 2110 1-3/8 5 9811 9000 series, Chrysler, EGR 4097 5125 2385 1-3/8 5
[Re: 62maxwgn]
#1510718
10/01/13 08:44 PM
10/01/13 08:44 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
And more.
The original Vaanth list...
Vaanth
[Re: plumcuda]
#1510719
10/01/13 10:21 PM
10/01/13 10:21 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I bought a new/unused 9810S at a swapmeet. It comes with an electric choke. Even though it was meant for a GM, I prefer this carb for my sb360 build. I don't see the carb linkage as being a problem. It will likely work out perfect for my cable/A500 trans swap. I am basically making this overall swap for fuel mileage considerations.
I have a competition 1000 cfm thermoquad. The linkage on it is very universal. It is a very simplistic carb when you look at it.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
