Street / Strip clutch--ideas? #1510461
09/30/13 10:12 PM
09/30/13 10:12 PM
Truckville, the capital of NY
85_Ram_4speed Offline OP
I have been doing some searching, but just curious what the opinions are here. I have a '85 D150 with a healthy big block and 4-speed in it (actually 833 OD). I need something that will hold the torque well, but will be street friendly---I know, its a big balance act. I just fried the unknown clutch combo in the truck the first time with this vehicle at the track. I got one really crappy run and then fried the clutch in the burnout box on the second run.
I had good luck in the past on another vehicle with the Centerforce D/F setup, but boy is it rough when you want to go flat out and power shift the thing. Thinking about just the CenterForce DF pressure plate and maybe a disk with less holding power to try and comprimise--but I think that is what the CF stage II clutch is. Or just suck it up and get some big static pressure B&B pressure plate and a organic disk---like an old school set up.
A $600+ setup is really out of the question at this point, so I need to be as budget friendly as possible.
What are your thoughts
Outcast Dodge guy.
Re: Street / Strip clutch--ideas? [Re: 85_Ram_4speed] #1510462
09/30/13 10:25 PM
09/30/13 10:25 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
Dump the Center Force and go with McLeod. I have had nothing but problems with CF.
This is what I am running, Part Number 360951 s the pressure plate I use then you can choose from Kevlar discs or a variety of materials
www.Mcleodracing.com
Re: Street / Strip clutch--ideas? [Re: 85_Ram_4speed] #1510463
10/01/13 12:03 AM
10/01/13 12:03 AM
I second the Mcleod. ran a stick 1 year on a circle burner & beat it to death & it never gave up. Heard other good feedback about it
Re: Street / Strip clutch--ideas? [Re: RapidRobert] #1510464
10/01/13 04:45 AM
10/01/13 04:45 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Another vote for McLeod.
I've put in so many clutches in my mopars I can't count them.
The McLeod I put in my bee earlier this year is hands down the best clutch and PP I've ever spent money on.
I can't afford this. mark
Re: Street / Strip clutch--ideas? [Re: a12superbee] #1510465
10/01/13 07:15 AM
10/01/13 07:15 AM
Ok, McLeod, but which one did you use? The first poster told me which PP he used which helps me.
Outcast Dodge guy.
Re: Street / Strip clutch--ideas? [Re: 85_Ram_4speed] #1510466
10/01/13 07:57 AM
10/01/13 07:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you had problems shifting with the CF it wasnt the clutch.Mine has been in my built 440 4 speed for years.At 6700 I fly thru the gears.It still hooks better than the Mc Cleod 3200 pound B&B that I had in it.Rocky
Chrysler Firepower
Re: Street / Strip clutch--ideas? [Re: therocks] #1510467
10/01/13 09:52 AM
10/01/13 09:52 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I would assume you are running the 10.5" flywheel?
http://www.brewersperformance.com/products.asp?cat=254
Any questions let me know.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Street / Strip clutch--ideas? [Re: 85_Ram_4speed] #1510468
10/02/13 04:40 AM
10/02/13 04:40 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
You mentioned 6 bills was a little much so I didn't post the part numbers.
I was giving thumbs up that McLeod (in my opinion) is a quality product, my last four or five kits were Rams and I don't see ever buying another one again.
My setup was about 550$ but was worth every penny compared to the Ram stuff and is the 'long' finger type.
Disk MCL 260851
PP MCL 360903
Bearing 16061
