91/93 Diesel fuel tank sending unit??
#1509859
09/30/13 09:32 AM
09/30/13 09:32 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
whats the olm rating??? I was under the impression that Mopar units were 73-10..
I am truckless..
Re: 91/93 Diesel fuel tank sending unit??
[Re: 340SHORTY]
#1509860
09/30/13 10:01 PM
09/30/13 10:01 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Im not sure, but that would make sense. I dont recall ever seeing a separate fuel gauge for a diesel. Guys that do diesel conversions on there trucks still use the factory gauge.
Do you have one that is acting up? There is a fix posted on one of the diesel forums, either 1st Gen or Diesel Bombers.
It involves using a light spring to keep tension on the traveling arm to keep the fuel gauge reading. After time the pivot wears, and allows for a gap to form. Causing loss of reading, or inaccurate readings.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: 340SHORTY]
#1509862
10/01/13 12:19 AM
10/01/13 12:19 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
FSM doesn't call out the ohm spec for either fuel type. I know a 88-91 TBI tank has the same specs as 83. That doesn't help with diesel but suspect it is the same.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
