I have a bog I can't seem to find on a 74 Challenger with 360. Here's what I know. Car has new carb and distributor. Someone installed HEI style distributor. Car has dual plane intake and 670 Holley. All new. Car runs perfect in park/neutral. Revs great...sounds awesome. Problem is car won't get out of it's own way in gear. Seems almost like it has a rev limiter when it is gear limiting it to around 2000 - 3000 rpms.
Basics.. Car has proper fuel pressure/volume (gauge). Timing advances perfect when in neutral/park. Timing doesn't seem to advance properly when car is in gear. I've taken distributor out and replaced with original style and still problem exits. Car holds great vacuum at idle (no leaks). I've change hot wire to distributor and still problem exists.
If this were a GM I'd be looking for a bad modulator on transmission or some reason this gear bogs so bad in gear.
What am I missing???? What can cause this problem when car is placed in gear?
