mallory 250 rebuild ?
#1506561
09/23/13 06:59 PM
09/23/13 06:59 PM
Posts: 3,210 robin hood country
deaks
robin hood country
My mallory 250 fuel pump took a dump the other week. It still works but pressure was very low, i just wondered if i could breathe new life into it. They do a rebuild kit for around 60 dollars, should i tackle it or just buy a new one ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: mallory 250 rebuild ?
[Re: jamesc]
#1506563
09/24/13 05:52 PM
09/24/13 05:52 PM
deaks
robin hood country
I run a single #12 to a robb mc filter then pump single #10 to the reg with 2 #8 to the carb and a #8 return from the tank. I will check which pump i have tomorrow. Mick
[Re: deaks]
#1506564
09/24/13 06:21 PM
09/24/13 06:21 PM
Posts: 5,875 communist bloc of new jersey
jamesc
so you're using a return style regulator up at the carb as opposed to a dead head style regulator at the carb with the return coming off the pump? if you are returning from the regulator at the carb i would check to make sure that is functioning properly first before i went after the pump. i ask about the pressure adjusting screw because the new/old style pumps take different rebuild kits. this is old style below ![](http://i.ebayimg.com/t/Mallory-5250-Fuel-Pump-Electric-Comp-Pump-250-Series-External-Universal-Each-/00/s/NDAwWDMwNA==/z/FhgAAMXQtRxSJNun/$(KGrHqN,!oMFILF)TiwqBSJNum8wy!~~60_12.JPG) this is new style below ![](http://i.ebayimg.com/t/Mallory-5250-Comp-250-Electric-Fuel-Pump-/00/s/MzAwWDQwMA==/z/Gs8AAMXQgb1RTN0g/$T2eC16dHJIQE9qUHuErhBRTN0f7qmw~~60_35.JPG) if you're using a return style regulator the center port shown with the label above it should be plugged and iirc there may be a steel plug that is installed in the regulator portion of the pump so maximum pressure is pumped to the return style regulator at the carb
[Re: jamesc]
#1506565
09/25/13 01:37 PM
09/25/13 01:37 PM
deaks
robin hood country
I'm using the larger holley reg with no return, just the return from the pump to the tank. Mick
