Page 2 of 4 1 2 3 4
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505945
09/23/13 11:09 AM
09/23/13 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Don... tell your brother to put some fancy smelling
race fuel in a baby food jar and when he needs a fix
to open it and get his sniff... tell him to save his
money and put 87 to 93 octane in the car.. he DOESNT
need race fuel
Re: Running a very low compression Engine on race fuel [Re: MR_P_BODY] #1505946
09/23/13 11:30 AM
09/23/13 11:30 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I know that back when racing gas was cheap and easy to get back in the early '90's, I would put some in my 9.3 compression 440 and the car ran OK.
I did find that I had to reset the float levels in the carb though. The other thing I noticed was that the engine ran rougher and at a higher decibel with pump gas vs. race fuel.
Often I would fill the tank at the track with the lowest octane leaded race fuel and run the car. It was only a little more in cost per gallon at a U.S. track compared to what pump gas cost in Canada.
The car ran so smooth and quiet with race fuel that I could actually have a conversation with someone in the car. With pump gas there would be yelling back an forth. The benefits of leaded race fuel would last for several tanks it I topped off the tank with pump gas several times while driving it on the street. It seemed to work for a couple of weeks which proves that I only needed the lead or a minimum octane boost to keep the engine happy.
I wish they still made gas like that at an affordable price.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Running a very low compression Engine on race fuel [Re: ProSport] #1505947
09/23/13 01:04 PM
09/23/13 01:04 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No it don't smell the same, not even close.
Re: Running a very low compression Engine on race fuel [Re: Crizila] #1505948
09/23/13 04:45 PM
09/23/13 04:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Sorry for the confusion. I thought this was a thread about octane #'S, not - smell. I ( or someone ) must be on the wrong web sight.
Fastest 300
Re: Running a very low compression Engine on race fuel [Re: Crizila] #1505949
09/23/13 04:53 PM
09/23/13 04:53 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
You came to the right place......lol
I actually started the thread because my little bro insists on thinking he needs 110 fuel in his 9.5 compression 360 n/a motor. I tried telling im it might negatively effect his performance, but he continues to run the stuff because he likes the smell of the stuff crazy...yep.....but if I can convince him his car will run better without it, may wean him of it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505950
09/23/13 04:58 PM
09/23/13 04:58 PM
ohio
all spooled up Offline
ohio
have him install some 14 to 1 pistons then he will need it
Re: Running a very low compression Engine on race fuel [Re: all spooled up] #1505951
09/23/13 05:03 PM
09/23/13 05:03 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Good idea, and he already has a 3/4 race cam in it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505952
09/23/13 05:10 PM
09/23/13 05:10 PM
ohio
ohio
3/4 race cam 9.5 1 comp
Re: Running a very low compression Engine on race fuel [Re: all spooled up] #1505953
09/23/13 05:11 PM
09/23/13 05:11 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Yea...and then some
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505954
09/23/13 05:19 PM
09/23/13 05:19 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
....a lite car with a big gear ...open headers ? .... he could ALMOST drink a case of beer and tinkle in the tank and THAT is all that is needed !! .... he likes the smell of race gas ? ... ... why doesn't he just set his wallet ON FIRE !!
Re: Running a very low compression Engine on race fuel [Re: dOrk !] #1505955
09/23/13 05:31 PM
09/23/13 05:31 PM
dogdays Offline
dogdays  Offline
You can't fix stupid!
R.
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505956
09/24/13 09:56 AM
09/24/13 09:56 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have an idea... we need a lightbulb over the head icon... NOBODY STEAL this from me now. So they make gas perfume in grape cherry, watermellon why not race fuel smell? huh? whatda y'all think? I could sell it to the OPs bro right??? whop else is in for a can??? now to go regester my plan, shoot I bet I can retire by next week.
Re: Running a very low compression Engine on race fuel [Re: dartman366] #1505957
09/24/13 11:02 AM
09/24/13 11:02 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Why in the world wouldn't he go make a couple runs on 93 octane? He could even put a dash of grape fuel fragrance from Summit, smells like race fuel, I've used it a couple times for car shows and car cruises.
It's my little brother... He won't listen to anything I tell him.
Most of the time he just likes firing it up in his garage, rapping on the gas pedal, and sniffing race gas fumes.... Would be sad if it wasn't true
The smell of Cam 2 is very addictive, there is nothing wrong with your brother just because he likes to fire up the motor to get his cam2 fix,I have done it before and I am ok.
Testing in California has shown that "breathing fumes from racing fuels may cause hair loss"....
If you like drag racing, support your local track.
Re: Running a very low compression Engine on race fuel [Re: CHAPPER] #1505958
09/24/13 11:21 AM
09/24/13 11:21 AM
Az
Crizila Offline
Crizila  Offline
Az
I guess that explains my reseeding hair line.
Fastest 300
Re: Running a very low compression Engine on race fuel [Re: CHAPPER] #1505959
09/24/13 11:28 AM
09/24/13 11:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... I guess I should be BALD.. being that I worked
in the fuel lab at Chrysler for 30+ years in that
one lab... but I have a full head of hair and a face full
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505960
09/24/13 01:58 PM
09/24/13 01:58 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have talked a few customers and friends out of 110 and into pump 93. One guy has been running 93 for several years now and won a track championship at 131 on it. On an 11 to one 455 Olds another customer gained 10 horsepower on the dyno with 93.
If you get into more of high rpm engine,race fuel can gain a little with low compression because it releases its energy faster .
I'll try the two on this 8.8 to 1 360 in a day or so and let you know just for the fun of it.
Keith
Re: Running a very low compression Engine on race fuel [Re: Dunnuck Racing] #1505961
09/24/13 04:17 PM
09/24/13 04:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Cool, Keith.
He has a little black 66 dart Gt with the factory white bucket seat interior.
360, eddies, 750 Holley, excellerator, 1/58 headers 904 and 8 inch.
Weighs 3300 with him, all steel, no fiberglass. Cam is a way to big 258@50 solid with his low compression motor. Car sounds like a healthy super stocker in the water box. been 11.38 with it but no better since the heads were done
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Running a very low compression Engine on race fuel [Re: Mr.Yuck] #1505962
09/24/13 07:14 PM
09/24/13 07:14 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
http://www.summitracing.com/search/produ...el%20Fragrances
At $12.97/4oz bottle, wouldn't it just be easier to buy a gallon of race fuel?
And those fragrance names, ROFL!
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: Running a very low compression Engine on race fuel [Re: 6pak2go] #1505963
09/24/13 09:37 PM
09/24/13 09:37 PM
fullmetaljacket Offline
I have 12.5 compression with aluminum 72 cc heads in my street motor and run straight 110 Sunoco, though I think it could be a tad faster with 108.
When cats here mention 93 pump gas, do they really mean the actual 93 octane pump gas that comes from the pumps at the local Mobil, BP, Sunoco, Shell? If it is, I suspect many of you may at some point have problems stemming from all that ethenal that floats in the stuff. that is why I strictly use 110. I wouldn't put pump gas in my Mini-bike.
An alternative to this would be 94 unleaded and 100 unleaded Sunoco/VP I guess.
Re: Running a very low compression Engine on race fuel [Re: fullmetaljacket] #1505964
09/24/13 10:49 PM
09/24/13 10:49 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I use the 93 super unleaded they sell at my local BP,Chevron and Texaco. Have been for years and have had zero issues.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Page 2 of 4 1 2 3 4
