Re: INDY 360-1 SPARK ADVANCE ?
[Re: Performance Only]
#1504296
09/20/13 11:04 PM
09/20/13 11:04 PM
Posts: 2,091 Delray beach, Florida
Performance Only
There seems to be a pretty common theme to most of the replies here. The OP is asking about timing for a pump gas combo and almost everyone has replied with a racing engine likely running higher octane race gas. Higher octane (maybe too high) needs more timing due to the slower burn. The engine masters combo is a totally different animal so there's no need to compare that one.
machine shop owner and engine builder
[Re: W5DART66]
#1504298
09/20/13 11:39 PM
09/20/13 11:39 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Jet for best MPH then start adding 1* see how it responds.
Don't get hung up on a number as that's all it is.
My deal was way rich for engine masters that's just how you have to run that deal.
But still it still wanted 38-40* on pump gas in a car and this was 10.75to1 flat top.
Guy on moparts has the engine in a D-50 truck and it runs well.
Maybe I should try more timing, I have only been running 35 degrees so far. THANKS Brett.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
#1504299
09/20/13 11:43 PM
09/20/13 11:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My W-2 engine on 87 octane likes 37*.. with the W-5s on it and 93 octane it liked 40*(on the dyno).. my W-9 likes 35* on E-85
#1504301
09/21/13 10:02 PM
09/21/13 10:02 PM
Posts: 28 AUSTRALIA
CLEVO351
AUSTRALIA
You are the only one that fully understands why i asked this question.
[Re: B G Racing]
#1504303
09/22/13 08:39 PM
09/22/13 08:39 PM
Posts: 28 AUSTRALIA
CLEVO351
AUSTRALIA
At 11.7 CR arn't you close to needing more octane?I agree with Dan that if your going to run 93 you want to less timing.
We are going to run in the engine on pump gas and then do some testing with E85.
[Re: CLEVO351]
#1504304
09/23/13 11:51 AM
09/23/13 11:51 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Why even mess with pump gas,just go to E-85 since it's completely different.Going to pump gas is only going to lessen the performance.At your CR I would baseline it with 104/110 then change to E-85 knowing you need to make changes to flow 25%/30% more.With 11.7 CR I would treat it to better fuel and timing for max power. I admit I'am not well versed on E-85 and suggest you consult with guys like AJ Casini or others but at your CR level running pump gas and less timing will drop power.If you were in the 10.0 CR range you may do that but at around 12.0 CR you can possibly hurt something or have a substancial power loss.
[Re: CRIKEY]
#1504309
09/25/13 12:06 AM
09/25/13 12:06 AM
Posts: 28 AUSTRALIA
CLEVO351
AUSTRALIA
35°-36° on 98 maybe, 1°-2° more on E85 depends whos E85 you use. I have never seen it need more then 36° on MS109 but at that static it may.
Was that on Shell 98 or Caltex,What capacity cid ? Did you Dyno and what power did it make? Thanks.
[Re: CLEVO351]
#1504310
09/25/13 12:32 AM
09/25/13 12:32 AM
Posts: 702 OZ
CRIKEY
super gas
super gas
OZ
