1978 Dodge 5.9l magnum swap #1503241
09/17/13 07:18 PM
09/17/13 07:18 PM
California
sattellite_pup Offline OP
California
Hi there, I am putting a 5.9L magnum into my 1978 Dodge True Spirit D100 truck. I have a few questions about wiring, sensors, speedo cable, fuel pump. I am putting in the engine, transmission, gas tank and all of the emission stuff. All parts came out of a 2000 dodge ram 1/2 ton truck I picked up and cut apart. I have to put in the emission stuff since I live in California and have to smog the vehicle when I finish. I am looking for someone that has done this before and what you did and possible some pics.
Thank you.
Re: 1978 Dodge 5.9l magnum swap [Re: sattellite_pup] #1503242
09/18/13 09:41 PM
09/18/13 09:41 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'm getting ready to do my 84 RC but I'm using a running driving 93 RC to do the swap
In doing so I'll use the 93' electronic speedo & everything.
I started to do this swap on my Crew using my old 97 sport the wife rolled for a total donor
I was doing my layout when I came to the tank/pump issue I found that it would be easier to use a 92-3 tank to do the swap
My 46RH had a gear for the speed sensor to use & I ran my speedo off it when I decided to go carb
Re: 1978 Dodge 5.9l magnum swap [Re: sattellite_pup] #1503243
09/19/13 06:15 PM
09/19/13 06:15 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I personally think you put yourself in a little pickle with the transmission from that 2000 as it is an electronic controlled transmision. The pre-97 (I believe that is the year cut off) are still hydraulic controlled transmissions with lockup and overdrive being the only internal electronincs.
As far as getting the engine wired up, I think someone on Ebay or here was modifying harnesses to work in older applications. Maybe they can shed more light on the later transmission usage too.
As far as getting the engine/trans in the truck, if you have a 93 trans crossmember for a 518 trans, then your all set and it all just drops in on the older D-series motor mounts (360 still needs the correct drivers bracket or washers to take up the space on the one bolt hole). Use a lower hose for a 93 truck and they will slip right on with your radiator and a top hose for your 78 truck. Trim as needed. Later BR-body trucks (94-2001) manifolds or shorty headers--or headers for a D-series truck will bolt right up to the engine and fit fine.
Hope that helps some, I only did a carb'd Magnum motor in my truck so there are other issues to deal with for that. They make excellent power stock and as with all Mopar small blocks, are dependable if cared for.
Outcast Dodge guy.
Re: 1978 Dodge 5.9l magnum swap [Re: 85_Ram_4speed] #1503244
09/20/13 01:05 AM
09/20/13 01:05 AM
California
California
Thank you 85_Ram_4speed, I will start looking for one of those cross members. The engine and trans are in the truck, trans being held up by a jack. We are going to swap out all of the wiring from the 2000 into the 78, from headlights to tail lights. Figure it will be the easiest way to fix the problem, put the dash from the 2000 into the truck as well. Also the rear end. Will document and post pics as we progress.
Thank you for the info.
Re: 1978 Dodge 5.9l magnum swap [Re: sattellite_pup] #1503245
09/20/13 01:37 AM
09/20/13 01:37 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC your going to find that the 2000 rearend is to wide for the 78...
I am truckless..
Re: 1978 Dodge 5.9l magnum swap [Re: 340SHORTY] #1503246
09/22/13 07:53 AM
09/22/13 07:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
why the headaches? you just want the EFI for daily driveability?
if this was my truck, I would consider one of 2 options...
maybe 3...
first, use the 5.9L magnum, swap in the intake with a Magnum carb intake. tell the idiots at the smog station that it's a 1978 360 V8. Do they really crawl all over and under the engine looking for casting dates? from the outside a 1978 360 V8 will look identical to a 2000 360 V8 unless you happen on a smog guy who REALLY knows his mopar stuff.
I had someone ask me if this was a 340 small block:
it's a 5.9L magnum, running factory EFI.
I went to a shop a couple weeks ago to get the suspension aligned after a spindle swap, and the guys who worked there, and are around cars all day, and who would call themselves "car guys" had no idea what engine it was, and had no idea it was a factory engine.
I bet if you put a carb on that 5.9, the smog guys at your shop won't know it's not a 1978 motor.
Now, if you're keeping EFI just because you want EFI, then I would run your original transmission and get a 5-spd computer to handle running the engine as a "stand alone" engine controller. (you could also get an early 90s OD trans with electronic lock-up/OD, and use vacuum switches to control the OD/Lock-up, or use manual switches, again, running the engine with a 5-spd computer)
Otherwise, I think the easiest thing for you to do would be to swap the 78s cab/body onto the 2000 truck's frame, because to use the 2000's engine, trans, computer, etc then you're going to need all the sensors, wire harness, speed sensor in the rear axle, dash gauges, OBD-II diagnostic plug under the dash, Evap system, Leak detection pump, O2 sensors/cats/exhaust... otherwise the computer will trip OBD-II emissions codes without having all that stuff there talking to the computer.
**Photobucket sucks**
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503247
09/22/13 11:59 AM
09/22/13 11:59 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
maybe 3...
The big problem is that we still have emissions testing on these trucks, and they still need to retain all of their emissions devices that they left the factory with, along with being functional. If he did a magnum engine with a carb on it he would be laughed at when it came to emissions testing.
I personally think he went too new. I like OBDII computer controled cars, but he is going to have to wire in a bunch of stuff(entire harness) to get it to work. He should have gotten a 92 or 93 truck to do the swap....that way it was more of a bolt in setup.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 1978 Dodge 5.9l magnum swap [Re: dynotune440] #1503248
09/22/13 12:37 PM
09/22/13 12:37 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I understand you have emissions testing still, but I think you missed the point behind what I said.
When you go in for your emissions testing, do they scour the motor to find a casting date? Do they look for a stamping to verify that it's the original engine?
A 1978 truck had a 360 as an original engine option, right? The 5.9 EFI engine can be switched to a carb, and bolted into the 1978 truck using 1978 engine mounts on the LA ears on the Magnum block...
So, how does the guy at the emissions testing station know that it's a 2000 5.9L Magnum motor and not a 1978 360 LA motor?
Shouldn't be that hard to make a carb'd motor meet 1978 standards.
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503249
09/22/13 01:29 PM
09/22/13 01:29 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Thats why you buy a Crate Magnum. No tb or carb so you get to decide
You seem to have Idiot "car guys" around you. Motor looks good though
Re: 1978 Dodge 5.9l magnum swap [Re: 76dodgeboy] #1503250
09/22/13 03:04 PM
09/22/13 03:04 PM
dynotune440 Offline
dynotune440  Offline
seriously...
Re: 1978 Dodge 5.9l magnum swap [Re: dynotune440] #1503251
09/22/13 03:16 PM
09/22/13 03:16 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
seriously...
The idiot Car guys was at his statement that the shop thought it was a different motor.
The crate motor was a joke as in ha ha. But on that not what are you suppose to do if your motor blows and you toss in a 72 motor because its what you have available? Do you have to go by engine yr emissions or truck year? If the magnum has better emissions that the stock setup why is that an issue?
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503252
09/22/13 03:19 PM
09/22/13 03:19 PM
dynotune440 Offline
dynotune440  Offline
first off..it depends on who you get...but if he is going on an engine change, it will smog to the year of the engine/chassis it came out of.
now, is there such an animal as an EGR spread bore intake for a magnum engine with magnum heads? in 78, we had air injection in the exhaust, and magnum heads dont have provisions for thatf
or California, you can do an engine replacement or engine change. a replacement is when you change within the same engine family..."LA 318", "LA 360"...and utilize engine emissions components from stock configuration. this will still utilize original. emissions standards. if you did an engine change, "RB 440", or a 350 GM engine... you will have to be of the same year or newer, and not degrade emissions standards....replace Cal emissions engine with federal emissions, or install a heavy duty emissions engine in a light duty emissions application.
Re: 1978 Dodge 5.9l magnum swap [Re: dynotune440] #1503253
09/22/13 03:21 PM
09/22/13 03:21 PM
dynotune440 Offline
dynotune440  Offline
a magnum engine is not a "LA" engine
Re: 1978 Dodge 5.9l magnum swap [Re: 76dodgeboy] #1503254
09/22/13 04:22 PM
09/22/13 04:22 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Well, yea, most people working at discount tire shops, quick lube oil change shops, and muffler shops are not known for their intelligence. How many 20-something year olds know the difference between a 440 big block and a 318 small block? Heck, I told the guys how my reverse lock-out on the T56 worked, (step on brake to shift into reverse) and he said "huh... My firebird has a T56 but it doesn't block you from reverse gear" I told him it did, but that it was controlled by the main engine computer snd was based on vehicle speed... Which was not an option on my 98 Dakota since it wasn't a factory transmission.
Now, these guys think of themselves as car guys, but do you really think they could identify original equipment vs looks original on a 30 year old truck?
Now, that said... No, there are no magnum heads with air pump ports, but there where magnums that had EGRs. I'm not familiar with what the emissions check people have at their disposal, books, pictures, etc. since I don't have to deal with that crap here, but do you HAVE to have that junk in there to pass emissions? Or can you tune an engine to pass a sniffer test without the pump, EGR, etc?
Re: 1978 Dodge 5.9l magnum swap [Re: dynotune440] #1503255
09/22/13 04:31 PM
09/22/13 04:31 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Right, we know that, but again... Does the guy at the emissions shop who drives a Subaru know that? How many guys walk into auto zone asking for parts for his 'Chevy 350' and when asked 'year, make, model' he replies with 'Dont matter, they're all the same'
But yes, my understanding from forums is that an older engine into a newer vehicle, emissions must meet the standards for model year of the vehicle. A newer engine into an older vehicle must meet emissions standards of the year of the engine.
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503256
09/22/13 05:22 PM
09/22/13 05:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Does Texas have emissions and inspections? I've thought of moving there but if I have to deal with emissions I'll stay put in Iowa. I was in my early 20s working in Walmarts Lube shop. I k.ew the difference lol. I've learned more over the years. My brother in law is 20 and thankfully isn't a Ricer. Him and his dad just got done with a 4.0 swap in his 76 AMC Hornet wagon(my old car)
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503257
09/22/13 05:26 PM
09/22/13 05:26 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
He knows what emissions equipment is supposed to be on the truck from the factory. And that equipment doesn't adapt easily to the Magnum engine.
Re: 1978 Dodge 5.9l magnum swap [Re: Cooter] #1503258
09/22/13 05:37 PM
09/22/13 05:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Duct tape and WD-40!
Re: 1978 Dodge 5.9l magnum swap [Re: 70Cuda383] #1503259
09/22/13 07:33 PM
09/22/13 07:33 PM
dynotune440 Offline
dynotune440  Offline
if it came with EGR and a smog pump, it has to be there and function. the state guys come in with those type of vehicles just to issue fines.. yes, there are books with pics of what one should look like.
Re: 1978 Dodge 5.9l magnum swap [Re: 76dodgeboy] #1503260
09/22/13 07:38 PM
09/22/13 07:38 PM
dynotune440 Offline
dynotune440  Offline
OK, time to sit back and drink some chelada
