Re: Ok so I broke a rod !
[Re: GTX MATT]
#1502659
09/18/13 11:23 AM
09/18/13 11:23 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I just built a 440 with Scat rods. Standard rod bolt not the ARP 2000 bolts. It ran 11.00's the first night out shifting at 6400 but when I went to check the timing the next day it had a noise coming from the bottom of the engine. When I pulled the pan I found one of the rod bolts hadn't been torqued and had backed out about 1/4". It was hitting the windage tray. The rod cap and opposite bolt where bent up. Amazingly the crank was fine and I replaced the rod and bearing and went 10.90's the next weekend.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: n20mstr]
#1502661
09/18/13 06:00 PM
09/18/13 06:00 PM
Posts: 854 Bloomingdale , OH
super451b
Bloomingdale , OH
im no expert....
BUT i would speculate that the cyl wall cracked....
filled that hole with some water and...then your rod broke
Re: Ok so I broke a rod ! head off more pics
[Re: dartman366]
#1502665
09/19/13 03:10 PM
09/19/13 03:10 PM
Posts: 969 OH--IO
360904
OH--IO
Re: Ok so I broke a rod !Oil Pan off New pics !!!
[Re: VernMotor]
#1502673
09/22/13 11:13 PM
09/22/13 11:13 PM
Posts: 782 wine country
8urvette
wine country
At that point I would cut my losses with that build and go for something different. How about a small block, with a nice set of twin turbos and fuel injection??? Or you can buy my 540 off me and ill build the TTSB Sorry to see that, I hate seeing other peoples carnage. For me, its just a chance for a new beginning. I get so side tracked that by the time I am close to finishing a project I am ready for something new any how.
