Re: Ok so I broke a rod !Oil Pan off New pics !!!
[Re: VernMotor]
#1502676
09/22/13 11:44 PM
09/22/13 11:44 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Jamie with the rod out in one pic it looks like rotational heat at the pin and another pic, just impact heat from hammering things about. With full floating wrist pins I cant see how any rotational heat could be possible. Someone else stated a cracked cylinder and then a hydrolock, if there is no readable rotational heat transmitted into the top part of the rod, then , thats probably what happend. From the new pics I cant tell, it looks like heat in one and not the other. You being there will be the best judge. No doubt at the rods main journal everythings fine. That is a very unhappy mess.
[Re: VernMotor]
#1502680
09/23/13 03:55 PM
09/23/13 03:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Jamie.. just looking at the first piston pic, do you think the wrist pin can out and took out the cyl wall.. I've seen failures before but on yours the pin is sticking out... doesnt look like the pin has any damage but cant see the other side... sorry about the breakage
[Re: VernMotor]
#1502682
09/23/13 09:06 PM
09/23/13 09:06 PM
MR_P_BODY
200 runs on the rods. Mike I thought about the pin. But as odd as it is. The only part of the cy wall that is still there is where the pin would ride. not a mark on it..??
OK... I found it a bit strange that the pin was out a 1/4" or so... when I've blown rods the pin has always been in tact and in the proper location but like you said the wall in that area was good... what about the opposite side... like it slid one way then busted out the wall and kicked it back hard enough to knock the clips out... just trying to think of the problem
[Re: VernMotor]
#1502684
09/23/13 09:58 PM
09/23/13 09:58 PM
MR_P_BODY
the clip/lock is still in the other side.
Well that rules that out... now I have to go back to thinking... that hard for me.. LOL... but I like to analise the "why it did it"
[Re: 375inStroke]
#1502686
09/23/13 11:40 PM
09/23/13 11:40 PM
Posts: 4,701 On the parachute mount
n20mstr
sorry guys, Im sticking to what i said ....
That cyl wall cracked and let the water in.
These blocks flex too much , thats it
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1502687
09/24/13 01:53 AM
09/24/13 01:53 AM
dartman366
Mt. Vernon, Ohio
I have stared at those pic's for a week now and the more I look at them the more I have to agree with you, I think the block failed and broke the rod when the piston fell into the void and tried to turn it on the rod to the point it pulled the top of the rod off,,look at the hole in the side of the piston and the gouge marks in the crown of the piston from where I feel the missing cyl wall caught the top of the piston.
[Re: dartman366]
#1502688
09/24/13 09:10 AM
09/24/13 09:10 AM
Posts: 694 Michigan
Super Scamp
You cracked the block she Hydroed and that's the evil coming out of that block..
Ask how I know.. look at this mess..
Just One Man's Opinion
Mopar Mafia Racing
[Re: dennismopar73]
#1502692
09/24/13 11:39 AM
09/24/13 11:39 AM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I think the cam broke !!!! JMO
I thought about this..Brand new cam. 50 runs on it.But you never know. Not sure we will ever know for sure. This block was sonic tested. I just don't know.
