Re: Ok so I broke a rod !
[Re: VernMotor]
#1502643
09/17/13 10:01 PM
09/17/13 10:01 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
What...you dont trust me????.... ![](/ubbthreads/images/graemlins/laugh2.gif)
RIP Monte Smith
[Re: VernMotor]
#1502647
09/17/13 10:08 PM
09/17/13 10:08 PM
Posts: 4,703 On the parachute mount
n20mstr
im no expert....
BUT i would speculate that the cyl wall cracked....
filled that hole with some water and...then your rod broke
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1502649
09/17/13 10:10 PM
09/17/13 10:10 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
im no expert....
You might be on to something there. The wall looks a little thin where it opened up. Sorry for your bad luck. It definitely looks expensive.
[Re: n20mstr]
#1502650
09/17/13 10:11 PM
09/17/13 10:11 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
im no expert....
At first I considered that too, but a broken rod at the wrist pin, will beat that area up pretty bad if its still attached to the crank, and it was.
[Re: Twostick]
#1502652
09/17/13 10:23 PM
09/17/13 10:23 PM
Sport440
Canton, Ohio
So what broke first, the piston, the rod or might it have seized a pin?
Kevin
With Jamies last post about no heat, and looking at the piston again, with it being beat out pretty good at the angle the rod would beat on it, is simply the rod broke first for sure IMO at the wrist pin, all else followed.
The good news, IMO is it got shut down fast enough to save the heads. Ive seen mayham spread to a bunch of other cylinders causing alot more damage to the rest of the chambers.
Re: Ok so I broke a rod ! head off more pics
[Re: dustergirl340]
#1502654
09/17/13 10:39 PM
09/17/13 10:39 PM
CompWedgeEngines
Syracuse,NY
You know Jamie Dustergirl....always showboating for the glamour shots !
I didnt look at them yet Jamie no.,
RIP Monte Smith
