Page 1 of 5 1 2 3 4 5
Ok so I broke a rod !Oil Pan off New pics !!! #1502595
09/16/13 05:46 PM
09/16/13 05:46 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Broke coming out of the water box. big hole big mess.
so here is what I seen when I pull off the head.
Head will live needs two new valves and some clean up.
top of the rod and part of the pin bushing
What do you guys think about this fuel wash Pattern on the piston ?
Tag 5 valves. bend the crank. Had to loosen the main caps to turn it over. crack one of the main caps.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502596
09/16/13 05:48 PM
09/16/13 05:48 PM
Guitar Jones Offline
I've broken 3 small blocks and one big block. The big block did more damage than any of the small blocks did. Broke the cam like yours too. Just build it bigger and badder this time.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502597
09/16/13 05:49 PM
09/16/13 05:49 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Yeah, a rod and then some more.
Sorry for your loss,
Re: Ok so I broke a rod ! [Re: AAR-B4] #1502598
09/16/13 05:51 PM
09/16/13 05:51 PM
tboomer Offline
tboomer  Offline
Crap!! Hate to see that,Vern...
Re: Ok so I broke a rod ! [Re: VernMotor] #1502599
09/16/13 05:56 PM
09/16/13 05:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Man that sucks..........what rods?
Re: Ok so I broke a rod ! [Re: Thumperdart] #1502600
09/16/13 06:00 PM
09/16/13 06:00 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Eagle's
Re: Ok so I broke a rod ! [Re: VernMotor] #1502601
09/16/13 06:04 PM
09/16/13 06:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Me too.............
Re: Ok so I broke a rod ! [Re: VernMotor] #1502602
09/16/13 06:05 PM
09/16/13 06:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
That sucks Vern, hopefully most of it is saveable.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Ok so I broke a rod ! [Re: Triple Threat] #1502603
09/16/13 06:11 PM
09/16/13 06:11 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
that suck's jamie
Re: Ok so I broke a rod ! [Re: VernMotor] #1502604
09/16/13 06:13 PM
09/16/13 06:13 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Eagle's
Did these replace the 440 source rods that you were running and having problems with?
Must see more when you tear this motor down.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502605
09/16/13 06:16 PM
09/16/13 06:16 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I didn't see it but heard the announcer over the loudspeakers...Sorry to see that.
At least it didn't happen while going over 100 MPH!
Re: Ok so I broke a rod ! [Re: dustergirl340] #1502606
09/16/13 06:43 PM
09/16/13 06:43 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
that's nasty
not that old were they ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Ok so I broke a rod ! [Re: dustergirl340] #1502607
09/16/13 06:44 PM
09/16/13 06:44 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Jamie I felt so bad for you, that really sucks
Re: Ok so I broke a rod ! [Re: dustergirl340] #1502608
09/16/13 06:45 PM
09/16/13 06:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sorry to see. Did it lock a bearing or just flat out break? If I never saw another motor failure for someone, I'd be happy.
Doug
Re: Ok so I broke a rod ! [Re: dvw] #1502609
09/16/13 07:16 PM
09/16/13 07:16 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Rod just broke on the small end. still bolted to the crank. spin's just fine. no discolor anywhere. rods have about 200 runs on them when I put them in this motor. new wrist pin bushing and bolts. look them over real good. car ran great on the last time run. no signs of anything wrong. good oil pressure in the staging lanes. wrist pin is still in the piston. I will take some more pics as I get it apart.
Re: Ok so I broke a rod ! [Re: VernMotor] #1502610
09/16/13 07:25 PM
09/16/13 07:25 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I heard about it and was going to come by and see you,but I didn't figure you needed company at the time.
Its always something.. Sorry for your luck.
Keith
Re: Ok so I broke a rod ! [Re: VernMotor] #1502611
09/16/13 07:31 PM
09/16/13 07:31 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Really sorry to see this Vern,,,,,tear it down and try and get a handle on what happened. Best of luck to you.
RIP Monte Smith
Re: Ok so I broke a rod ! [Re: VernMotor] #1502612
09/16/13 08:17 PM
09/16/13 08:17 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Sorry, never good news no matter who it is.
Sheldon
Re: Ok so I broke a rod ! [Re: RUNCHARGER] #1502613
09/16/13 08:39 PM
09/16/13 08:39 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
oh man that looks painful
Re: Ok so I broke a rod ! [Re: VernMotor] #1502614
09/16/13 08:58 PM
09/16/13 08:58 PM
Central New York
bfury Offline
bfury  Offline
Central New York
I was in the stands when you broke. Sorry to see that. Looks like an expensive repair. Best of luck with the rebuild. See you next year.
No Stock
