Cal-Tracs #1501732
09/15/13 12:32 PM
09/15/13 12:32 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Well after trying drag shocks, spring clamps and whatnot (and going backwards each time) I guess I need to bite the bullet and buy a set of cal-tracs. I see them on 'bay for $338. Does anybody have a cheaper price?
Coming soon!!!!
Re: Cal-Tracs [Re: Mr.Yuck] #1501733
09/15/13 12:49 PM
09/15/13 12:49 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Do yourself a favor and buy them direct from Calvert. That way you can tailor them to your set-up.
"Just a Bracket car dressed up like a streetcar"
Re: Cal-Tracs [Re: Just-a-dart] #1501734
09/15/13 12:50 PM
09/15/13 12:50 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Their website is down, no hurry I guess. What do I need to tell them?
Re: Cal-Tracs [Re: Mr.Yuck] #1501735
09/15/13 12:51 PM
09/15/13 12:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
you could try moneymakerracing, that's where i found my best price. 219-861-1214
you could also try FBO,dont have his number.
Re: Cal-Tracs [Re: Mr.Yuck] #1501736
09/15/13 12:58 PM
09/15/13 12:58 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Are you going to do springs too?
Re: Cal-Tracs [Re: Just-a-dart] #1501737
09/15/13 01:39 PM
09/15/13 01:39 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
trying to avoid that if possible. I'd just like to be in the 1.52-1.55 range. Best so far was 1.60 but most of the time I was in the 1.68-1.72 and after the drag shocks and clamping the front segments I'm in the 1.78-1.84 range... If I load the convert up it's not as bad, but if I use the converter it just blows the tires off. I typically feel it spin 3-4 times before it "digs" A buddy at the track says I have too much rear end lift. I tried 70-30 and 50-50 on the rear shocks...not sure if 40-60 would do much.
Re: Cal-Tracs [Re: mopar dave] #1501738
09/15/13 02:12 PM
09/15/13 02:12 PM
Locomotion Online content
Locomotion  Online Content
Alex, Beth & Tony are all racers. They run Fords, but they're good people and have helped many racers over the years. When I'm ready to get some, I'll be giving them a call.
MoneyMaker Racing
Re: Cal-Tracs [Re: Mr.Yuck] #1501739
09/15/13 03:11 PM
09/15/13 03:11 PM
Rancho 9-way or the Cal-Trac adjustable shocks should help. I believe that the more power you make and the harder the suspension gets "hit", the stiffer the shocks need to be.
Re: Cal-Tracs [Re: Mr.Yuck] #1501740
09/15/13 03:44 PM
09/15/13 03:44 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did you unclamp the back of your springs and have long drag shocks?? unclamping the back lets the front part of the spring work.
Too short a shock tops out and unloads. adjustable shocks as part of cal tracs really works to slow down that extension.
I had better launches with my SS springs than with the mono springs but i think i got too stiff of mono springs.
Re: Cal-Tracs [Re: Dodgem] #1501741
09/15/13 05:17 PM
09/15/13 05:17 PM
ill
dennismopar73 Offline
ill
Save your self money and dis appointment ! get a floater and ladder bars be done!
or ladders and coils either one better cal tracks, and floaters,
As for calling them direct foget about that! they where no help at all to us after the sale because they have no idea what or how to set up your car! that they will tell you is your deal! all they can tell you is a basic start ! after that you test n tune them
good luck!
Re: Cal-Tracs [Re: dennismopar73] #1501742
09/15/13 09:15 PM
09/15/13 09:15 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
good luck!
I found just the opposite...they helped me and if they have a car damn near standing on the back bumper they must be doing something right ....
*Caution* Mr Yuck you need to get the springs as well they work better as a package ...i have gone 1.45 60' with a 275 drag radial in a 3700 lbs car they take time but they work
Re: Cal-Tracs [Re: 10secGTX] #1501743
09/15/13 09:29 PM
09/15/13 09:29 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
You talk about it blowing the tires off when you launch at a higher RPM...90% of making a car hookup is in the FRONT end...what do you have up there?? If it's not lifting the front tires off the ground, you've got more work to do up front...
If you can't handle the truth, you're living a lie.......
Re: Cal-Tracs [Re: Mr.Yuck] #1501744
09/15/13 09:30 PM
09/15/13 09:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hey MrYuck,
I run the caltracs on stock HD mopar springs in my 68 Satellite , average 1.52 60'
I run rancho rear shocks set full tight and QA1 single adjustable front shocks set full loose
Calvert were helpful so is the section on yellowbullet . maybe I was lucky , set up as per Calvert not changed since
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Cal-Tracs [Re: 10secGTX] #1501745
09/15/13 09:30 PM
09/15/13 09:30 PM
ill
ill
Glad they helped you out, I can only go by the exspereance we had with them!
Some seam to have good luck with them we have had quite the differance there as well.
In fact the cal tracs are coming off this winter we will go back to super stock springs as the car left faster off them !
for half the money!
the cal tracks will either be sold off or scrapped makes zero dif to me at this point!
$1,100 worth of wasted money!
Re: Cal-Tracs [Re: Dodgem] #1501746
09/15/13 09:31 PM
09/15/13 09:31 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I didn't unclamp the back...I have the summit version of the Comp Engr drag shocks. I was told I might need to clamp the 1st and 2nd rear segmant as well. I was thinking of getting some SS springs but was told that's old technology...I'm not sure what the full extended lenght of these shocks are.
The car isn't really that fast, maybe these springs are just whoooopppped.
As for ladder bars, I'd rather not. I'm no welder and I have to drive 30 or 52 miles each way to the track not sure how that ride would go.
Re: Cal-Tracs [Re: Big Squeeze] #1501747
09/15/13 09:35 PM
09/15/13 09:35 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
standard 90/10's...I know a 70 charger is not an ideal race car but my 67 12.08 coronet had a better 60 foot...w/ a sway bar. It had newer XHD springs and JC Whitney coil over rear shocks.
Re: Cal-Tracs [Re: Mr.Yuck] #1501748
09/15/13 09:39 PM
09/15/13 09:39 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
MrYuck,
clamp the front , unclamp the rear
I have 2 on front , removed the rear most clamp on the rear side
I footbrake , no transbrake
Tex
New best MPH 130.32
Re: Cal-Tracs [Re: Big Squeeze] #1501749
09/15/13 09:41 PM
09/15/13 09:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
This seems to be a huge secret for some reason. I doubt the OP wants to make the front end right for truly picking up the 60's.
Most of the people that don't like the results of any suspension don't do what is required to get them to work. Full of excuses and no real addressing the true issue.
None of these pieces are a magic beans that will pick your car up if the chassis as a "harmonious unit" isn't working well.
Ask member Punk how well cal tracs worked on their car... pretty darn good running low 1.4x's on 275 drag radials and 10.60 et's. It's gone 1.37's/ 10.52 on slicks and with Afco shocks. Go look up what those calculators say his car should run in the 1/4 for that 60'... LOL
Re: Cal-Tracs [Re: tex013] #1501750
09/15/13 09:42 PM
09/15/13 09:42 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
side shot
Tex
New best MPH 130.32
Re: Cal-Tracs [Re: Mr.Yuck] #1501751
09/15/13 09:59 PM
09/15/13 09:59 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I was thinking of getting some SS springs but was told that's old technology...I'm not sure what the full extended length of these shocks are.
There are still only four ways to spring a car, leafs, coils, torsion, or air. Thats it. Cal-Tracs are still leaf springs, albeit they are mono-leafs, but still leaf springs.
The springs will determine the range of motion, the shocks determine the timing of the motion.
I'd verify you have adequate shock travel, unclamp the rear segment, and see where that leaves you before moving to the front motion. Maybe have a buddy video tap your launch and post it up here.
