Page 2 of 3 1 2 3
Re: 750 carbs on 700hp motors [Re: B3422W5] #1501020
09/14/13 12:31 PM
09/14/13 12:31 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
In a nutshell, a top tier Super Stock motor is LIGHT YEARS away from what is typical motor head builds. There is no area of John's motor that's not looked at for HP...those guys address things that I would never even think of...
But to his point...our 30 year old 800 DP is quicker in 60' by .05 than the new high dollar Holley (true 950 cfm) HP that we have now. Who knew???
Re: 750 carbs on 700hp motors [Re: B3422W5] #1501021
09/14/13 12:31 PM
09/14/13 12:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I agree, part of that is the cam being in early to trap more cylinder pressure. That is one of the best lobes UD/Bullet has, asymmetrical with an agressive opening and slower closing ramp, 183 @ .200 lift.
With more cr I would agree the combo wouldn't want or need as much stall, I think the soft 60' is the trade-off of the cr/head flow mismatch but you sure cant argue with the awesome results all thing considered
John calverts super stock mustang is a very highly scienced-out race car, not really an apples to apples regarding the very tricked out induction system, camshaft and exhaust, the hp and performance are the result of years and years of tweaking that car/class/combo and chassis going back to the early 70's, and with a few allowances (to enhance ET's for increasing class parity over the decades) along the way. It is an awesome car to behold.
In this day of back halved purpose built FWD conversion cars being legal in SS it's amazing the 40+ yr old cars can still compete at all, but I'm really glad they still can
WIZE
In Car:
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501022
09/14/13 01:27 PM
09/14/13 01:27 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I thought it was working quite well
I've thought the same thing and then hooked up my LM1 and see it was fat on the hit. Changed pump nozzles and picked up the 60.
NMCA NSS 67 Coronet
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501023
09/14/13 02:57 PM
09/14/13 02:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
408 small block. 60 is a consistant 1.51.
do you have a 700hp Small Block? what's the et and mph? whoops et and mph were in the Op... Yeah I'd think at that et you'd be in the low 1.40's. still good numbers.
Re: 750 carbs on 700hp motors [Re: B3422W5] #1501024
09/14/13 06:23 PM
09/14/13 06:23 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
frank lupo at dynamic built the vert at 5400 stall because at the time my peak tq was at 5100 and he suggested 300 above peak for vert stall. since I had cam regound 10* less dur. I would geuss stall now would be about 5000. I do use a 1" 4 hole spacer.
Re: 750 carbs on 700hp motors [Re: AndyF] #1501025
09/14/13 06:34 PM
09/14/13 06:34 PM
Mt Morris Michigan
Mt Morris Michigan
yeah,but its about 5 yrs old now. not quite up to date. jesse a good carb man and he suggested his 950 stage 5+ which is a 850. plugs show it could use alittle more timing reading the ground strap. the color change is just about to the bend,so maybe a degree or 2? i'm at 36* now. 38* sounds like too much for a 11.3:1 408 on pump gas though?
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501026
09/14/13 06:36 PM
09/14/13 06:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ummm ground strap is plug heat range
http://www.youtube.com/watch?v=fiMM2S0aADM
Re: 750 carbs on 700hp motors [Re: B3422W5] #1501027
09/14/13 06:39 PM
09/14/13 06:39 PM
Mt Morris Michigan
Mt Morris Michigan
230cc intake port, 14# in the QTP's
Re: 750 carbs on 700hp motors [Re: Quicktree] #1501028
09/14/13 07:39 PM
09/14/13 07:39 PM
Mt Morris Michigan
Mt Morris Michigan
yes,i watched that video last week and read on ngk site heat range was read on ground strap. so I called ngk and talked to one of their techs and he tells me timing is read off the ground strap. so,go figure.
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501029
09/14/13 07:41 PM
09/14/13 07:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
ok so who you trust Larry Meaux one of the best head porters engine guru's or the NGK tech that probably has never raced or messed with a car.
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501030
09/14/13 07:50 PM
09/14/13 07:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly..........too many opinions on this according 2 who you talk 2.............
Re: 750 carbs on 700hp motors [Re: Thumperdart] #1501031
09/14/13 07:59 PM
09/14/13 07:59 PM
Q
Quicktree Offline
Quicktree  Offline
Q
true but can you explain how timing can affect the strap?
Re: 750 carbs on 700hp motors [Re: Quicktree] #1501032
09/14/13 08:15 PM
09/14/13 08:15 PM
Mt Morris Michigan
Mt Morris Michigan
I hear it both ways all the time,but lately more an indicator of timing. I was under the impression the more timing the more heat.
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501033
09/14/13 08:21 PM
09/14/13 08:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
timing doesn't control the spark, just when it happens.
Re: 750 carbs on 700hp motors [Re: Quicktree] #1501034
09/14/13 08:25 PM
09/14/13 08:25 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I can't explain how it does but when I advance the timing in my car it moves the discoloration on the strap further towards the end of the strap. Some of the guys I talk to with forced induction say that you want the discoloration at the bend of the strap. Might be two different things but that's what happened with my car
Re: 750 carbs on 700hp motors [Re: 80arrow] #1501035
09/14/13 08:27 PM
09/14/13 08:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea boost is a whole different story.
Re: 750 carbs on 700hp motors [Re: Quicktree] #1501036
09/14/13 09:02 PM
09/14/13 09:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can`t explain crap................
Re: 750 carbs on 700hp motors [Re: Thumperdart] #1501037
09/14/13 09:08 PM
09/14/13 09:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it's an interesting subject. I wish someone who really knows could explain it. Larry Meaux is well respected. thats the way I have always tuned my cars. who knows there is a lot more to it trying to read fuel rings and all that crap.
Re: 750 carbs on 700hp motors [Re: Quicktree] #1501038
09/14/13 09:20 PM
09/14/13 09:20 PM
Mt Morris Michigan
Mt Morris Michigan
I was told heat range was read from the first 3 threads from the bottom of the plug. should be golden in color(ngk) for proper heat range. i'v used the strap to get timing right now for quite some time and its seemed to work for me. whatever
Re: 750 carbs on 700hp motors [Re: mopar dave] #1501039
09/14/13 10:01 PM
09/14/13 10:01 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
i'll have to contact a carb shop to see what it takes in a smaller carb. jesse bigs setup my 950 and I thought it was working quite well in my 408 with 11.4 comp, indy heads and intake,260/269-700 lift cam, 1 7/8 headers, 5500 8" stall, 727, 4.10, 28" tire. 67 cuda weights 3300 with me and my 60 is a 1.51. best [Email]10.39@131[/Email]
Dave my 416 Dart @ 3200 lbs w/4.56 & 29" tires w/caltrks. Ran a best 60' of 1.47. Usually 1.48-1.50 @ 125mph. I had ported W2's and the cam was 265@.050 590 lift installed @108. TA 4400 converter hat flashes 5400. Carb is a stock PF 950HP. Your running about where I would expect with that combo. JMO
Page 2 of 3 1 2 3
