a904 cheetah reverse manual valve body trans no foward
#1500829
09/13/13 02:47 PM
09/13/13 02:47 PM
Posts: 11,915 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
A904 trans ,fresh,new T/A cheetah reverse manual valve body, start engine, reverse is fine,no foward gears, any ideas?
Re: a904 cheetah reverse manual valve body trans no foward
[Re: Joesixpack]
#1500830
09/13/13 02:54 PM
09/13/13 02:54 PM
Posts: 20,697 in a cattle trailer down by th...
Guitar Jones
No rear clutch apply, no forward gears. You could drop the valve body and do some air pressure checks. The front clutch and rear band servo are working though if you have reverse.
edit: don't hit the clutches with 150 psi of shop air though, you shouldn't need more than 30 psi to see if they are working.
[Re: Joesixpack]
#1500833
09/19/13 07:09 PM
09/19/13 07:09 PM
Joesixpack
APACHE JUNCTION AZ
pan off...draining....valve body next,trans guy coming sat to do the air checks....if we cant figure it out then out comes trans i will have him go thru it...looking for a core for a spare,V8 A904 non lock up.all ready have rebuild kit&spare Chettah RMVB. UPDATE just located a spare a904 trans in Elgin,getting it today...gonna rebuild it, and R&R with trans#1, figure out what is wrong with it,fix it and have a spare trans for 2014.
