Twin Scoop Hood Factory Paint 71 Cuda #1499899
09/10/13 11:24 PM
09/10/13 11:24 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
While removing some components and trim from the original hood to my 71 Cuda I found some interesting points and wanted to share them.
Car is a 71 340 Cuda convertible with SPD 3/31/71.
As best I can tell this hood has not been repainted.
The point of interest is how I think the diecast scoops were painted at the factory.
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499900
09/10/13 11:25 PM
09/10/13 11:25 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
If you look closely you can see (4) dots of paint.
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499901
09/10/13 11:26 PM
09/10/13 11:26 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Other side
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499902
09/10/13 11:27 PM
09/10/13 11:27 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Scoop nuts
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499903
09/10/13 11:28 PM
09/10/13 11:28 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Paint under nuts
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499904
09/10/13 11:29 PM
09/10/13 11:29 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Backside Scoop
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499905
09/10/13 11:30 PM
09/10/13 11:30 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Scoop and gasket
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499906
09/10/13 11:32 PM
09/10/13 11:32 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Scoop with insert removed
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499907
09/10/13 11:38 PM
09/10/13 11:38 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Based on what I see here I beleive the scoop was set on the hood prior to paint without attaching hardware and without the well nuts for attaching the black insert. Possibly the scoop was spaced up from the hood a little bit on one end. After paint the scoop was lifted off, gasket installed and attached to hood.
I find this interesting becasue prior to this I thought the scoops were attached to the hood prior to paint.
I'm curious what others have found.
Mike Afflerbach
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499908
09/10/13 11:39 PM
09/10/13 11:39 PM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
also here you can see that there was very little paint on the back underside of the hood
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499909
09/12/13 11:53 PM
09/12/13 11:53 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Mike,
Concerning the hood scoops:
I have found similar findings on my 1970 `cuda340 convertible. SPD 421.
BTW: Does your car have H6XW H51?
Ola
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaized] #1499910
09/15/13 10:04 AM
09/15/13 10:04 AM
SE PA
cudaize Offline OP
cudaize  Offline OP
SE PA
Ola
The interior is H6X9 and it does not have air. It has a black power top, black billboard, console auto, AM radio, S74 fast ratio power steering, 323 open rear.
Re: Twin Scoop Hood Factory Paint 71 Cuda [Re: cudaize] #1499911
09/15/13 12:48 PM
09/15/13 12:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I noticed this also many years ago pulling a hood apart.
A couple of other observations that hopefully will be clarified/confirmed/denied by others.
These are old memories, a bit faded.
The nuts had no paint. They were not used to hold the scoop up from the hood during painting.
There was not a distinct line on the studs to indicate the height they were held up from the hood. No shadow around the holes on the underside from the studs blocking paint.
There was no distinct pattern under the scoop showing an outline of something used to hold it away from the hood.
The paint on the scoop ended very close to the outside edge. No attempt to cover the underside.
