Rocker arm recomendations #1498949
09/09/13 12:49 PM
09/09/13 12:49 PM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I'm having problems with aluminum roller rocker arms. They flex too much and I can't keep them adjusted. If I tighten them too much I pull the threads out of the rockers. I run Shubeck lifters and an aggressive stock eliminator cam shaft. Minimum seat pressure is 230 lbs. I'm thinking of going with stainless steel roller rockers. I see Comp Cams has some that may work. I'd like to know what you guys are using.
Raul
Re: Rocker arm recomendations [Re: Aspen7695] #1498950
09/09/13 01:01 PM
09/09/13 01:01 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Comps ultra pro magnums are bushed and they are holding up fine in my solid roller cam'd small block.
Re: Rocker arm recomendations [Re: Aspen7695] #1498951
09/09/13 01:03 PM
09/09/13 01:03 PM
Locomotion Offline
Locomotion  Offline
I'm using Harland Sharp roller rockers and might find a couple that are a thousandth or two off after a race weekend. But I "only" have 170-180 lbs on the seat.
Re: Rocker arm recomendations [Re: DJVCuda] #1498952
09/09/13 07:21 PM
09/09/13 07:21 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have these on my big block and like them. About 220 on the seat, 500 over the nose. Mine are older and had bronze bushings installed.
Re: Rocker arm recomendations [Re: Aspen7695] #1498953
09/10/13 12:15 AM
09/10/13 12:15 AM
Raul
Is this a BB or SB Mopar and if a SB is it early motor with single shaft rocker arms or the later Magnum type motor with stud mounted rockers? If a single shaft type on either size motor try a set of Harland Sharp aluminum roller rockers or a set of T&D single shaft rocker arms
Re: Rocker arm recomendations [Re: Cab_Burge] #1498954
09/10/13 04:43 PM
09/10/13 04:43 PM
Gilbert, AZ
Gilbert, AZ
Thanks for the suggestions. I can't run Harland Sharps because they need a longer valve to make the geometry correct. They said to run lash caps and they will be fine. NHRA says no lash caps in stock eliminator. Oh, the motor is a 360 LA. I am leaning toward the Comp Magnums.
Raul
Re: Rocker arm recomendations [Re: Aspen7695] #1498955
09/11/13 12:42 AM
09/11/13 12:42 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
You might want to talk with Bob Mazzolini in Riverside, CA or Don Little in Westley, CA (Nor Cal) about Stock Eliminator motors. They have been at it forever and I just remembered Rettig Bros in Modesto are very good as well.
