1969 440 warranty block #1498410
09/08/13 05:52 PM
09/08/13 05:52 PM
Keminmaa
ArcticCuda Offline OP
Keminmaa
Are pads always this empty?
1970 Plymouth GTX 440-6
1970 Plymouth PPR Cuda 489-4
1971 Plymouth Duster Bad Romance 408-W2-8bbl
Re: 1969 440 warranty block [Re: ArcticCuda] #1498411
09/08/13 05:53 PM
09/08/13 05:53 PM
Keminmaa
Keminmaa
Cast date
Re: 1969 440 warranty block [Re: ArcticCuda] #1498412
09/08/13 05:59 PM
09/08/13 05:59 PM
Keminmaa
Keminmaa
One more.
Re: 1969 440 warranty block [Re: ArcticCuda] #1498413
09/08/13 09:19 PM
09/08/13 09:19 PM
california
Mr D21 Offline
Mr D21  Offline
california
sure does look like DA grinder marks where the vin once was ??
Re: 1969 440 warranty block [Re: Mr D21] #1498414
09/08/13 09:44 PM
09/08/13 09:44 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I have seen a lot of blocks with mill marks like that, not aggressive enough in my opinion to be DA marks.
Have no idea, on the original question.
EDIT: Never mind, I thought you were talking about the top machined area, not the VIN pad.
Careful, your character's showing!
Re: 1969 440 warranty block [Re: Mr D21] #1498415
09/08/13 11:26 PM
09/08/13 11:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep usually they only go from top left to bottom right all the way across the VIN pad and no machine marks go from top right to bottom left like in the middle of that VIN pad IMO too
Re: 1969 440 warranty block [Re: A12] #1498416
09/09/13 03:43 PM
09/09/13 03:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You might have an over the counter block. My warranty block still had the markings on the pad but none on the vin pad, it also has a blue plate attached to the pass. side freeze plug boss with a steel rivet.
Re: 1969 440 warranty block [Re: ArcticCuda] #1498417
09/09/13 07:00 PM
09/09/13 07:00 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I have been told that usually there is an "S", for "service replacement", as shown below. The engine below had a blank vin pad but I don't have a pic of it.
Re: 1969 440 warranty block [Re: cudaman1969] #1498418
09/10/13 11:12 AM
09/10/13 11:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you realize that anyone counter walk up to the parts counter and PURCHASE the short block assembly that you are calling a warranty block? It would be stamped the same way AND have that little blue tag ...
Warranty block is as misused/abused a term as RADIO DELETE
Re: 1969 440 warranty block [Re: JohnRR] #1498419
09/10/13 03:51 PM
09/10/13 03:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sure could, but it still came out of the warranty stock that were rebuilt engines, vin ground off and the blue tag. The parts dept. never bought a new non rebuilt short block or long block, that I know of. I knew one 440 car that was out of warranty and he bought a short block though parts, can that be called a warranty block?
I'm in the cabinet business and people want a laminate counter top but they still call it Formica, a brand name. Sounds like you're just nit picking.
Re: 1969 440 warranty block [Re: ArcticCuda] #1498420
09/10/13 04:13 PM
09/10/13 04:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since a new replacement block was never "built" there wouldn't be any "build" data stamped on it.
Re: 1969 440 warranty block [Re: A12] #1498421
09/10/13 04:25 PM
09/10/13 04:25 PM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
I've seen pads with distinct mill marks and some that aren't visable at all. To say "they go from top left to bottom right" imo is misleading It depends on where the mill operator starts his cut, mill speed, cutter depth and it's condition.
IMO, on trying to decide if a pad has been tampered with, it's the size of the mill marks. They give an idea of the cutter diameter that Chrysler used..
I've personally seen them all over the place
Re: 1969 440 warranty block [Re: 52savoy] #1498422
09/10/13 05:18 PM
09/10/13 05:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Why wouldn't the VIN pad be set up to be machined the exact same way everytime? They were not done by a hand grinder (like that looks like ) They produced in one plant at least a thousand cars a day so why would they not be done with a fixed milling process?
Re: 1969 440 warranty block [Re: A12] #1498423
09/10/13 06:40 PM
09/10/13 06:40 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
If you compared 100, 1969 440 blocks (which were all machined at the Trenton Michigan engine plant), the VIN pad should look pretty much the same. They consistantly used a certain diameter cutter to machine the pad.
I don't think this VIN pad has been tampered with other than a little Scotch Brite disc to clean it off.
Re: 1969 440 warranty block [Re: A12] #1498424
09/10/13 06:42 PM
09/10/13 06:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I agree. I would think all the surfacing, deck, oil pan, and top would be done at the same time set in a crank jig, even front and back surface. Moving from different machines would be hard to keep true.
Re: 1969 440 warranty block [Re: Dave Watt] #1498425
09/10/13 07:17 PM
09/10/13 07:17 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I agree. A hand grinder would not look that good. It could just be an end mill with a little wore spot on it to make a mark. This crowd suspects fraud in every post>
Re: 1969 440 warranty block [Re: fastmark] #1498426
09/10/13 07:29 PM
09/10/13 07:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'm not suspecting fraud, just that the marks don't look like they were original milling marks. There is no way that VIN pad had any numbers stamped on it and no way were they ground off even if there were any there in the first place. Look closely at the top angled part of the VIN pad, it's as originally milled and not any wider or lower. Not fraud but not original factory marks either.
Re: 1969 440 warranty block [Re: Dave Watt] #1498427
09/10/13 07:52 PM
09/10/13 07:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Which gets dull over time, the finish from a fresh milling cutter will look way different than one that's worn and ready to be changed.
Re: 1969 440 warranty block [Re: John_Kunkel] #1498428
09/10/13 08:13 PM
09/10/13 08:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's my E440 HP over the counter long block without a VIN stamped....
Re: 1969 440 warranty block [Re: John_Kunkel] #1498429
09/11/13 12:14 AM
09/11/13 12:14 AM
State of retirement
State of retirement
but the non-believers don't want to hear...
I based my observation as a retired machinist plus owning a few mopars helps. I know what caused the swirl marks but it would lead to others questioning(doubting) me on that too.
I go back to my first post.. cutter speed, wear on it and set-up... also shift change and maintenance.
I've seen many original blocks with marks like that.
How many big blocks were made? over 7million and all the same?
You haven't seen that so therefore it's a fake?
I've got a '68 casting block('69 production) but with a '66 stamp. Is it a fake? No. It was stamped wrong.
last comments.. It could have been removed by someone. On all the blocks I've seen... Chrysler machined the vin pad parallel to the side of the block. To REMOVE all the vin, the cutter or grinder has to be set at an angle which will clearly show it's not parallel.
I would like to see the block up close..
