Re: Trans trouble?
[Re: VernMotor]
#1497677
09/07/13 11:53 PM
09/07/13 11:53 PM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
You took the cover off the rear end and looked at it ?
Yes but more like totally out,pulled axles,brakes with just the gears in it.
Re: Trans trouble?
[Re: Clanton]
#1497680
09/08/13 10:44 AM
09/08/13 10:44 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
She rolls freely forward.I feel the binding is likely planet gears but I have all A&A stuff,4 pinion,steel drum...Cope if you see this PM me we need to talk $$.
What rear sprag do you have, Low band apply ?
Re: Trans trouble?
[Re: VernMotor]
#1497686
09/08/13 04:14 PM
09/08/13 04:14 PM
Posts: 26,530 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Output shaft seized in the rear support would be my guess....or a distressed sprag. Either way it should come out for inspection.
Re: Trans trouble?
[Re: Clanton]
#1497688
09/08/13 08:11 PM
09/08/13 08:11 PM
John_Kunkel
Rio Linda, CA
A healthy factory sprag will usually make a squealing noise when turning the tailshaft in the forward direction...not sure if the Coan will too.
Re: Trans trouble?
[Re: John_Kunkel]
#1497689
09/08/13 09:01 PM
09/08/13 09:01 PM
Clanton
northern,Ohio,USA
I got a spare yoke to turn the output shaft and the planet gear inside the shell[front clutch reatainer] looks to be where the trouble is.I think maybe a snap ring came loose or something holding a gear in that shell. I tested it in all but park.
