Re: Blow By
[Re: PossessedDuster]
#1497390
09/07/13 03:39 PM
09/07/13 03:39 PM
Posts: 655 MN
astrobuf
MN
You don't say when it was rebuilt. My guess is that the engine got too hot at some point and the rings are trashed. Blow by as you see it is a sign that the compression rings are not working. You are not clear whether it also is fouling the plugs, if so, that would be a sign of the oil rings being stuck too.
If the build was a home job, it's possible the guy did a poor/coarse hone job and then installed Moly rings. The coarse hone would destroy the moly in short order and leave this problem too.
Astrobuf
So, are you really a Rocket Scientist?
Re: Blow By
#1497392
09/09/13 01:58 AM
09/09/13 01:58 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
You will need to tear it down to assertain the internal damage to make a decision on whats needed to repair it...
I am truckless..
