Re: What overdrive trans fits a 440 ?
[Re: Kern Dog]
#1497012
09/08/13 10:15 PM
09/08/13 10:15 PM
Posts: 12,521 Western Colorado High Desert
moparmarks
Isn't the 518 a bit if a tight fit in cars? Don't you have to cut metal out of the trans crossmember to clear the larger diameter tailshaft housing?
The 73-up B's have a way different x-member than all the others. It needed minor clearing. On most everything else, A, E and 72-down B, yes major cutting in needed. Trucks, vans and MH's should be pretty easy install.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1497013
09/09/13 10:40 AM
09/09/13 10:40 AM
Posts: 12,813 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
http://www.cuda-challenger.com/cc/index.php?topic=84774.0Apparently, no major cutting is involved. This is the way I am planning on going and I will not cut up my Cuda. I just picked up a 518 out of a 3/4 ton. $175 from the pick-a-part yard with the wiring and lines. And they pulled it.
Master, again and still
[Re: moparmarks]
#1497015
09/10/13 10:10 AM
09/10/13 10:10 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I would like to consider going this route on my 73 Charger but I would want to know what snags you run into. I am afraid of having to cut or modify anything where it couldn't be reversed. My car is numbers # engine and tranny and I would want the option to roll it back to original.
If I can get a tranny cross member/mount fabricated for my car, did you have to cut anything else? I know shorten the driveshaft but I would buy an extra for that.
What mods to the 74 Charger did you have to do?
[Re: cjskotni]
#1497016
09/17/13 09:26 PM
09/17/13 09:26 PM
Posts: 53 Connnecticut
acesneights
Connnecticut
Thanks guys for the advice. GV is big bucks. I like the 518 idea but the only thing that would scare me is cutting the bellhousing. Everything else no problem. It is a Dodge M500 chassis. Loads of room to make anything fit. The only issue I could see is having to lose the Ebrake brake on the driveshaft which does not work anyway and was a joke when it did.Might as well nail an old shoe to a stick and call the the emergency brake shoe. I'd like more info on the 518 bellhousing swap and cutting the 518. Everything else I can handle . I can have the driveshaft modded up the street and I am a welder.
1975 Dodge Travco 440 BB
1972 Dodge Travco 318 SB
[Re: it's Bob]
#1497018
09/17/13 10:32 PM
09/17/13 10:32 PM
acesneights
Connnecticut
Awesome vid. Thanks, you are right. I could easily do that although I am having a hard time believing that the pump bolts can hold that power. Bo Duke was awesome BTW. Still looks great. So Ultrabell says you can only use an 11" TC. Will that work in n RV ? Can I get a low stall speed in that size ? Also which flexplate would I want and do I want the diesel a518 or gasser ? IS there a difference ? I would assume there is.
[Re: acesneights]
#1497019
09/17/13 10:59 PM
09/17/13 10:59 PM
acesneights
Connnecticut
Also I am not well schooled on 440's. Being that mine is an RV do I have a steel or cast crank ? How can I tell and what does that mean with respect to flexplate and TC and balance ?
[Re: acesneights]
#1497020
09/18/13 12:27 PM
09/18/13 12:27 PM
Posts: 350 Houston
it's Bob
Houston
Power, well it works for the drag racing guys. I would hazard to guess that they are putting down some serious HP/torque. When you cut off the factory bell you will be surprised at how thin the Al is in places. And how thick the Al is on the Ultrabell...which leads to this..
The UB is a very thick Al casting. It has to be to get the SFI burst rating for the TC and the other parts that might try to come flying out in the event of a failure. As such you can, with time and some effort clearance the inside of the bell to accept a 12" converter if that really is the way you want to go. You would need to remove a bit more than 1/2" of metal all the way around the inside for several inches in. Lots of work/time. UB will tell you that you might need to grind the starter pocket area as well to make some factory style starter noses fit as well.
