97 Ram 1500 lowering shackles #1496832
09/05/13 10:30 PM
09/05/13 10:30 PM
IA
moparmoondog Offline OP
IA
I want to buy and install the 1"-2" lowering shackles on my 97 Ram 1500 2-WD (see attached photo). If I do the 2 inch drop will I need to shim my pinion angle, and if so how many degrees? Any help will be greatly appreciated.
Many thanks,
Moparmoondog
Re: 97 Ram 1500 lowering shackles [Re: moparmoondog] #1496833
09/08/13 12:01 AM
09/08/13 12:01 AM
MO
C_Notch Offline
C_Notch  Offline
MO
i wouldn't if it was my truck. never shimmed to correct pinion angle on anything ive lowered and have never had any problems.
Lowered 99 dakota, 03 ram 1500, 09 ram 1500, and 84 D.
Re: 97 Ram 1500 lowering shackles [Re: C_Notch] #1496834
09/09/13 05:05 PM
09/09/13 05:05 PM
IA
IA
Thanks for the info!!!
