check the BATT wire running along the pass side VC some have a spade plug some dont.
on my 85, I kept blowing alt/VR/headlights/fuses till I found the burnt plug. just as it get to the firewall/wireharness.
I also cut open the rubber triangle piece on the driver side inner fenderwell, 1 wire from batt and 3-4 fusable links off of it.
that is where you will start finding the fusable links. I can post some pics of my 85 and the wirenut fix I did to fix all the trouble.
now I go straight to that with every truck and patch it before I ever have trouble.
my 440 truck wireharness got striped down to a few wires totale to run the whole truck.
make sure the grounds are clean and check ground right off bulkhead connector at firewall.
if I had only figured that out before 6 headlight bulbs,2 radios, and all the dash bulbs in a 3 week time frame. 3 yrs and no truble since.
