Braided hose leaking #1493378
08/31/13 08:49 AM
08/31/13 08:49 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
saw a fuel under my Duster. it was coming from the bypass return line. I removed the line and sealed it then added some pressure and here's what I discovered. never had a leak like it before this one.
home of the
Sox and Martin Hemi Duster
Re: Braided hose leaking [Re: HEMIFRED] #1493379
08/31/13 08:50 AM
08/31/13 08:50 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
that turned into
home of the
Re: Braided hose leaking [Re: HEMIFRED] #1493380
08/31/13 10:07 AM
08/31/13 10:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Under the pretty stuff its still just rubber hose. Rotten from age maybe ???
Re: Braided hose leaking [Re: Stanton] #1493381
08/31/13 10:41 AM
08/31/13 10:41 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
I have no idea when it was installed but don't remember replacing it. The #10 and others I remember ?
home of the
Re: Braided hose leaking [Re: Stanton] #1493382
08/31/13 11:28 AM
08/31/13 11:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... thats all it is... just a fancy outer with
hose inside... time will kill the hose... also if its
been sitting without fuel(once fuel has been in it)
the air seems to help dry it out(actually its the
fuel but the air shows it up better)... a few years
ago I had the same thing on my hose(same stuff)...
looked great but fuel would leak through.. this was
on the supply side... it was about 12 years old..
I dont know why but it seems they like to leak NEAR
the fittings... I havent seen them leak in the middle
of a line... like the hose gets twisted during assembly
Re: Braided hose leaking [Re: MR_P_BODY] #1493383
08/31/13 11:44 AM
08/31/13 11:44 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
for as long as I can remember a new hose gets my homemade pressure checker test. about 50lb for fuel lines. 150 for oil system
home of the
Re: Braided hose leaking [Re: HEMIFRED] #1493384
08/31/13 12:09 PM
08/31/13 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At work we use to test new samples from vendors but
we used a oil in a pressure pump to burst it so it
wouldnt explode... it would just piss out oil and drop
in pressure
Re: Braided hose leaking [Re: HEMIFRED] #1493385
08/31/13 12:38 PM
08/31/13 12:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I stopped using the metal braided stuff last year and went to the Earls lightweight stuff w/nylon outer and alcohol compatable hose......no more bloody fingers when cutting/assembling and it`s not the "cheap stuff" inside.
Re: Braided hose leaking [Re: Thumperdart] #1493386
08/31/13 01:40 PM
08/31/13 01:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW with pump gas that is not very unusual. Some of the additives in pump gas will tear up the inner rubber layer on steel braided hose over time. Some areas seem to do it quicker than others. I have replaced numerous lines on street cars over the years,
Re: Braided hose leaking [Re: Al_Alguire] #1493387
09/01/13 12:15 PM
09/01/13 12:15 PM
an8sec70cuda Offline
I had to replace a section of my return line last year for the same reason. Backed the car out of the garage to go to the grocery store and saw a trail of gas. Crawled underneath to see it dripping. It was leaking through the metal braid, but not near a fitting. It was in the middle of a 4' section.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Braided hose leaking [Re: an8sec70cuda] #1493388
09/01/13 12:30 PM
09/01/13 12:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
This is why hard line should be used as much as possible and only use small sections of flex where you need to. Less is better when it comes to braided hose. I would never use it to go front to back.
Braided hose is only good for a few years until it needs to be replaced and that was before ethanol.
I honestly replaced all my braided hose on my 250mph dragsters every 3rd year. Run them 2 years and replace them. My fuel system sit's on a too expensive motor to take chances. And after 2 seasons there is evidence of corrosion starting on some of the fittings. If one little speck of the corroded aluminum get's stuck in one of my fuel nozzles, then it would burn a piston and torch the head, sleeve and block costing a few thousand dollars to repair.
Even my oil lines to the remote filter got replaced and all were pressure tested to 300psi and tagged.
A TAD can kill you very easy and fast.
Braided line is no guarantee of anything, they suck for the most part, but you have to use them in some places.
Re: Braided hose leaking [Re: Challenger 1] #1493389
09/01/13 03:30 PM
09/01/13 03:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we have replaced WAY more return lines that supply lines on most cars. My theory is the vapors are causing the issue as many of the return lines when sitting may not be completely full of liquid fuel. Just a theory but we have replaced return lines way more frequently than supply ones.
Re: Braided hose leaking [Re: Al_Alguire] #1493390
09/01/13 04:52 PM
09/01/13 04:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats true... vapor most of the time is more problematic
than full liquid
Re: Braided hose leaking [Re: MR_P_BODY] #1493391
09/01/13 05:13 PM
09/01/13 05:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
PTFE line, no rubber.
Re: Braided hose leaking [Re: RobX4406] #1493392
09/01/13 05:22 PM
09/01/13 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I like Viton lined hose... Viton is pretty much
impervious to anything... all the hose we used at
Chrysler was Viton lined
