Page 2 of 4 1 2 3 4
Re: Homebuilt Caltrac/Slide-a link copy [Re: clutch] #149245
11/18/08 03:29 PM
11/18/08 03:29 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Thanks!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149246
11/18/08 04:03 PM
11/18/08 04:03 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
Here they are
Re: Homebuilt Caltrac/Slide-a link copy [Re: clutch] #149247
11/18/08 04:27 PM
11/18/08 04:27 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Now all you need is the length of the rear attaching point on the spring plate.
Getting old just means you were smarter than some and luckier than others.
Re: Homebuilt Caltrac/Slide-a link copy [Re: dannysbee] #149248
11/18/08 05:10 PM
11/18/08 05:10 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
THANKS MARK!
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149249
11/18/08 05:27 PM
11/18/08 05:27 PM
do you weld the rear attachment ears directly to the existing shock plate or do you weld them to a separate plate???
Re: Homebuilt Caltrac/Slide-a link copy #149250
11/18/08 05:41 PM
11/18/08 05:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You could try to weld the plate to the current shock plates.
I built my own:
Re: Homebuilt Caltrac/Slide-a link copy [Re: RobX4406] #149251
11/18/08 06:26 PM
11/18/08 06:26 PM
Nice!
I'll take a set!
Re: Homebuilt Caltrac/Slide-a link copy #149252
11/21/08 01:24 AM
11/21/08 01:24 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Ohh looky:
From this:
To this:
They are over-square because of the shape of my leaf spring at the eye. It has an on-center spring eye.
Man I love my plasma cutter.
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149253
11/21/08 08:31 AM
11/21/08 08:31 AM
why the extra holes? adjustability?
Re: Homebuilt Caltrac/Slide-a link copy #149254
11/21/08 08:45 AM
11/21/08 08:45 AM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
Swiss cheese lightweight racing versions...
Re: Homebuilt Caltrac/Slide-a link copy #149255
11/21/08 09:24 AM
11/21/08 09:24 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Yes.
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149256
11/22/08 10:45 PM
11/22/08 10:45 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Worked some more today.
The spring plate on the Ranger is not flat so I decided to add a flat section. So I plasma'd 2 - 5.25" x 2.5" x .25" pieces.
Then I cut out 2 chunks of 2' square tube.
Then I drilled a hole for the bolt and plasma'd one side out and welded them to the flat pieces.
This is how it fits in.
This is the final product. The shiny black paint made taking a good pic hard. I should have shot it with flat for the pic.
That's all for now.
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149257
11/23/08 11:42 AM
11/23/08 11:42 AM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
This thread needs to go to the the tech archives. Thank you!
Re: Homebuilt Caltrac/Slide-a link copy [Re: moparpollack] #149258
11/23/08 07:37 PM
11/23/08 07:37 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
agreed!!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Homebuilt Caltrac/Slide-a link copy [Re: topfueldart] #149259
11/23/08 07:57 PM
11/23/08 07:57 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
this guy has skill for sure.......
Mopar Performance
Re: Homebuilt Caltrac/Slide-a link copy [Re: moparpollack] #149260
11/23/08 08:15 PM
11/23/08 08:15 PM
Toronto Ontario
Butt Ugly Offline
Butt Ugly  Offline
Toronto Ontario
Or should it go to the FBI or maybe to China, Seams to me like this is a blatent infrigment of a patent
One guy builds his own, maybe OK maybe not. Sharing with others kinda
If people are to profit( improved 60ft ) from this thread, sorry, I would be peeved if I was the original manufacturer.
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Homebuilt Caltrac/Slide-a link copy [Re: Butt Ugly] #149261
11/23/08 08:18 PM
11/23/08 08:18 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
just the slightest variations makes it legal.. however I bought ALL my caltracs (real)stuff from a vendor on here regardless....
Mopar Performance
Re: Homebuilt Caltrac/Slide-a link copy [Re: Butt Ugly] #149262
11/23/08 09:32 PM
11/23/08 09:32 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
I'm not selling them, nor making them for other people. Just showing guys how much fun I have been having in my shop.
RMRW 2018
RMRW 2020
Re: Homebuilt Caltrac/Slide-a link copy [Re: BBR] #149263
11/23/08 09:58 PM
11/23/08 09:58 PM
Toronto Ontario
Butt Ugly Offline
Butt Ugly  Offline
Toronto Ontario
Maybe just bad timing, brother n law is going through the courts trying to protect some technologies from a former employee. Not car/mpar related. Just stuck a nerve as I read the thread.
And your work rocks
Re: Homebuilt Caltrac/Slide-a link copy [Re: Butt Ugly] #149264
11/26/08 12:10 AM
11/26/08 12:10 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Tubing came today and it is only threaded on one end... pooooop. Luckily, one of the guys I work with happens to have a 3/4"-16 tap. It is not LH thread, but that's ok. It will just make making bar adjustments a little more involved. At least with RH-RH, if the jam nuts vibrate loose, the bar can not change length.
All hail the king of caterpillar welding.
Running total update:
3/16" plate = $8.00
steel tubing = $36.00 (1" x 24" DOM internally threaded 3/4"-16)
grade 8 bolts = $22.00 (2)9/16 x 4, (2)5/8 x 3, (2)5/8 x 4, (2)3/8 x 3.5 and nylock nuts.)
Subtotal = $66.00
All I need now are the rod ends, and 2 pieces of 3/8" ID tubing cut to 3" (which I have) and I will almost be ready to bolt them in.
RMRW 2018
RMRW 2020
Page 2 of 4 1 2 3 4
