Drive shaft removal - need some help
#1492341
08/29/13 11:54 AM
08/29/13 11:54 AM
Posts: 36 MD
rkh17
MD
I need to pull my transmisison for some refurb work and starting to look at how to disconnect my drive shaft. Car is a 1974 Dodge Challenger and the trans is an A833.
Looks like the rear end side of the shaft is pretty straight forward. Just the four bolts.
Transmission side of the shaft doesn't have the same bolts so I'm assuming it's some type of clip inside.
Any special tools to help get the job done? I have a lift and high jack stand, high trans jack already.
Pics attached.
Thanks for your assistance in advance.
-Rob
RobH -- 72 Plymouth Duster 360 73 Dodge Charger SE 318 74 Dodge Challenger 340-4 74 Dodge Challenger 440
Re: Drive shaft removal - need some help
[Re: rkh17]
#1492342
08/29/13 11:56 AM
08/29/13 11:56 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Just unbolt the straps at the back, and slide the entire thing out of the transmission...no need to unhook anything up front. (Once you unbolt the back you will see the front is a slip joint and will just slide out towards the back) To remove the driveshaft itself from the front yoke, you remove the little ujoint clips and press it apart.
[Re: Tesla_HV]
#1492345
08/29/13 12:10 PM
08/29/13 12:10 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Put tape around u-joint caps on rear so they dint fall off after you unbolt joint.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: rkh17]
#1492357
08/29/13 10:50 PM
08/29/13 10:50 PM
Posts: 36 MD
rkh17
MD
Progress - drive shaft is out. Was pretty simple with the tips for working it out. unbolted the rear and dropped it and the other end slipped right out.. Had the oil catch set up and ready for the drips...
[Re: rkh17]
#1492358
08/29/13 10:51 PM
08/29/13 10:51 PM
Posts: 36 MD
rkh17
MD
Looks like a touch of surface rust near the end. Worth cleaning that up while I wait for my transmission work to be completed?
[Re: rkh17]
#1492360
08/29/13 11:32 PM
08/29/13 11:32 PM
moparpollack
Lil Herman
Lil Herman
85086
Get a pogo stick to hold the engine up while you remove the transmission.
