Re: Homebuilt Caltrac/Slide-a link copy
[Re: BBR]
#149246
11/18/08 04:03 PM
11/18/08 04:03 PM
Posts: 1,491 S.L . MI
clutch
S.L . MI
[Re: clutch]
#149247
11/18/08 04:27 PM
11/18/08 04:27 PM
Posts: 5,160 Texas
dannysbee
Texas
Now all you need is the length of the rear attaching point on the spring plate.
Getting old just means you were smarter than some and luckier than others.
[Re: BBR]
#149249
11/18/08 05:27 PM
11/18/08 05:27 PM
do you weld the rear attachment ears directly to the existing shock plate or do you weld them to a separate plate???
#149250
11/18/08 05:41 PM
11/18/08 05:41 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
You could try to weld the plate to the current shock plates.
I built my own:
[Re: RobX4406]
#149251
11/18/08 06:26 PM
11/18/08 06:26 PM
#149252
11/21/08 01:24 AM
11/21/08 01:24 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Ohh looky: From this: To this: They are over-square because of the shape of my leaf spring at the eye. It has an on-center spring eye. Man I love my plasma cutter.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#149253
11/21/08 08:31 AM
11/21/08 08:31 AM
why the extra holes? adjustability?
[Re: BBR]
#149256
11/22/08 10:45 PM
11/22/08 10:45 PM
BBR
Amarillo, Texas
Worked some more today. The spring plate on the Ranger is not flat so I decided to add a flat section. So I plasma'd 2 - 5.25" x 2.5" x .25" pieces. Then I cut out 2 chunks of 2' square tube. Then I drilled a hole for the bolt and plasma'd one side out and welded them to the flat pieces. This is how it fits in. This is the final product. The shiny black paint made taking a good pic hard. I should have shot it with flat for the pic. That's all for now.
[Re: BBR]
#149257
11/23/08 11:42 AM
11/23/08 11:42 AM
moparpollack
Lil Herman
Lil Herman
85086
This thread needs to go to the the tech archives. Thank you!
[Re: moparpollack]
#149258
11/23/08 07:37 PM
11/23/08 07:37 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: BBR]
#149263
11/23/08 09:58 PM
11/23/08 09:58 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Or should it go to the FBI or maybe to China, Seams to me like this is a blatent infrigment of a patent One guy builds his own, maybe OK maybe not. Sharing with others kinda If people are to profit( improved 60ft ) from this thread, sorry, I would be peeved if I was the original manufacturer.
I'm not selling them, nor making them for other people. Just showing guys how much fun I have been having in my shop.
Maybe just bad timing, brother n law is going through the courts trying to protect some technologies from a former employee. Not car/mpar related. Just stuck a nerve as I read the thread. And your work rocks
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
[Re: Butt Ugly]
#149264
11/26/08 12:10 AM
11/26/08 12:10 AM
BBR
Amarillo, Texas
Tubing came today and it is only threaded on one end... pooooop. Luckily, one of the guys I work with happens to have a 3/4"-16 tap. It is not LH thread, but that's ok. It will just make making bar adjustments a little more involved. At least with RH-RH, if the jam nuts vibrate loose, the bar can not change length. All hail the king of caterpillar welding. Running total update: 3/16" plate = $8.00 steel tubing = $36.00 (1" x 24" DOM internally threaded 3/4"-16) grade 8 bolts = $22.00 (2)9/16 x 4, (2)5/8 x 3, (2)5/8 x 4, (2)3/8 x 3.5 and nylock nuts.) Subtotal = $66.00 All I need now are the rod ends, and 2 pieces of 3/8" ID tubing cut to 3" (which I have) and I will almost be ready to bolt them in.
