1968 + 1970 Charger Dash Question...
#1492263
08/29/13 08:52 AM
08/29/13 08:52 AM
Posts: 338 ontario, canada
cool_cuda
ontario, canada
Hey guys! I have a few questions my friend has a 1968 Charger R/T hes working on. When he got the car it came with a 70 dash. my question is will it work? what do we have to change ( lower dash panel,ignition switch ect ect)I know he really needs an R/T 68 dash to be 100% correct but he just wants it to work/ driver. 2) Whats a 70 Dash really worth in the real world? 3) Anyone got a 68/69 dash they might want to swap or sell? Thanks in advanced!
Re: 1968 + 1970 Charger Dash Question...
[Re: cool_cuda]
#1492264
08/29/13 09:11 AM
08/29/13 09:11 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
It'll pretty much work, but you will have no flasher/emergency switch. In the '68, it was in the instrument cluster under the dimmer switch. Not sure what it is worth, but it will definitely be worth more than a '68/69... I doubt you will find a situation where you can get a complete swap, but best of luck in trying. You definitely should be able to sell it and then come up with the funds to get yourself a '68/'69 Rallye/Charger dash. That '70 looks to be in pretty nice original condition to be honest. Also, was the VIN transferred from the original dash to this '70?
I would throw this picture in the for sale section or trade and see what happens...
Cheers,
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1492265
08/29/13 09:28 AM
08/29/13 09:28 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Cheers,
what he said, I'd try and sell that complete and buy the correct dash. I think some of the harness is going to be different as well. In 70 the ingnition switch is in the column. I'm guessing that dash is from an S/E???
[Re: Mr.Yuck]
#1492266
08/29/13 09:47 AM
08/29/13 09:47 AM
hemi68charger
Houston, Tx
Or some unfortunate R/T...... All Charger R/T's in '70 had woodgrain dashes...
The only thing I might question is the light switch. The '70 has a electrical headlamp motor, so the circuit for that is in the headlamp portion of the dash harness. The '70 Dash switch doesn't have the provision for the vacuum switch either ( unless it is from a Superbird )...
The gauge connection on the printed circuit board is the same. Also, is the wiper switch in the '70 dash a 3-speed or 2-speed switch? Is the wiper motor in the car a 2speed or 3speed? Washer switch will be the same along with the dimmer switch. The 2 radio plugs ( speaker & power/light ) should be the same........ The heater and/or a/c switch panel will probably be different too...... If it is non-a/c, should be a problem...
[Re: hemi68charger]
#1492267
08/29/13 09:52 AM
08/29/13 09:52 AM
Mr.Yuck
Brookeville, Md
yeah that too.. maybe the VIN is still there and he can make a few more $$$$ JUST KIDDING
[Re: Mr.Yuck]
#1492268
08/29/13 01:32 PM
08/29/13 01:32 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
Each year dash frame '68 - '69 - '70 is different, ignition switch mounting is the biggest difference '68 vs. '69.
'68 dash is Charger, Super Bee, & Coronet R/T w/gauges ONLY. '70 wood grain dash shown is Charger R/T and/or SE, Super Bee, Coronet R/T w/gauges, & GTX ONLY (dash frame and gauges also used in Road Runner/Charger - no wood grain panels).
