Page 2 of 5 1 2 3 4 5
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14892
03/12/05 09:39 AM
03/12/05 09:39 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
They sound pretty darn nice!
Rich H.
Esse Quam Videri
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14893
03/12/05 10:12 AM
03/12/05 10:12 AM
on a side note....i have 2 sets of Bulldogs in the shop as well.
one set is the last version prior to them raising the intake ports,
I'm curious as to what those flow, they might be the ticket for an exhaust manifold combo???
Wayne
Re: Indy 440-EZ's are here!!! [Re: v8440] #14894
03/12/05 10:42 AM
03/12/05 10:42 AM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Dwayne, you're scaring me here with those flow #'s on the EZ-1. It's looking like they're better than the SR's I ordered, at least on the intake. What's the deal?
thats EZ(pun intended )....they are better....on the intake side anyway.
its a newly designed casting and they improved upon what they had before.
the exhaust port however is never gonna flow what an SR exhaust can flow. its just smaller, and lower.
Curtis, i assume that SR is MW size?? whats the finished runner volume??
Brad, wont be anything more done to these until they are sold, and then only what the customer is looking for.
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14895
03/12/05 01:07 PM
03/12/05 01:07 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Just out of curiosity do think that Indy will use this newly designed port in the SR`s as well?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14896
03/12/05 01:36 PM
03/12/05 01:36 PM
Yes, .. MW port, .. 298 cc runner, ..
Curtis
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14897
03/12/05 02:07 PM
03/12/05 02:07 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
man the number of cylinder head choices for BB chryslers is greater than you'd ever expect. how's indy's quality control as far as guides, seats ect.? i've seen negative posts about this but the finish machine work (specifically bores) they did on a mega block for a friends mill was very nice. it's nice to have decent flowing heads that don't require zillion dollar offset rockers.
Re: Indy 440-EZ's are here!!! [Re: jamesc] #14898
03/12/05 02:57 PM
03/12/05 02:57 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Dwayne the EZ line looks very good, perhaps even an improvement to the original Indy line at lower cost; and that's what they should be. Now they should revamp the originals (they seem to have done that for the CNC line). From a cost standpoint Jeffs Modern Cylinderhead CNC Eddies still give the EZ and original lines (OOTB), a run for the money. At least from what I've seen at this point. I'm curious what your talent will take these OOTB numbers to. Thanks for posting the info. I always look forward to your postings.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Indy 440-EZ's are here!!! [Re: racealittle] #14899
03/12/05 03:35 PM
03/12/05 03:35 PM
Canada
RobR Offline
RobR  Offline
Canada
Cool...now for some pictures
Re: Indy 440-EZ's are here!!! [Re: RobR] #14900
03/12/05 06:31 PM
03/12/05 06:31 PM
Alta Loma, Ca
cuda440 Offline
super gas
cuda440  Offline
super gas
Alta Loma, Ca
cool #'s...
not that it really matters, but couldn't Indy at least come up with an actual "name" for their cyl heads? i gotta say 440-EZ sounds pretty lame, like something for convelescent seniors with incontinence.
70 pro street cuda...still a project
Re: Indy 440-EZ's are here!!! [Re: cuda440] #14901
03/12/05 08:12 PM
03/12/05 08:12 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
any pics yet?
Re: Indy 440-EZ's are here!!! #14902
03/12/05 08:28 PM
03/12/05 08:28 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Curtis
those sound like some killer SR's there Curtis, very very interesting! Id like to hear more about those!
Re: Indy 440-EZ's are here!!! [Re: 5537SG] #14903
03/12/05 08:39 PM
03/12/05 08:39 PM
Yep, .. but not on Dwayne's thread, hijacking threads
is not pollite. Use e-mail.
Curtis
Re: Indy 440-EZ's are here!!! #14904
03/13/05 01:23 AM
03/13/05 01:23 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The muscle motors 440-1 heads seem to have some problems, just got a set in a few days ago, they have had the SMP port job, the valve stem height varied more than I like to see, the worst being .020 deeper, sure what happened must have been in the seat machineing or valve job, also the shims varied from head to head, one head had the standard .050 bronze shims, the others had a mixed matched aluminum .030 thick with another .020 steel black shim, Needless to say I will be contacting them Monday on this.
Re: Indy 440-EZ's are here!!! [Re: Bob_Coomer] #14905
03/13/05 03:05 AM
03/13/05 03:05 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Indy, second after installing 2.25 intakes and porting by R&J out of Iowa. "
whos the porter in iowa..??
Re: Indy 440-EZ's are here!!! [Re: 493_DART] #14906
03/13/05 11:06 AM
03/13/05 11:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like a nice head. Nothing wrong with more choices for sure. Now where are those danr pictures
Re: Indy 440-EZ's are here!!! [Re: fast68plymouth] #14907
03/13/05 11:23 AM
03/13/05 11:23 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Just what we need another cylinder head that flows in the mid 340 cfm range.This is why (most) mopars cant run with the other brands in the fast or heads up classes.To bad all this effort isnt used to develop good blocks and cylinder heads that flow in the high 400/500 cfm range.
Re: Indy 440-EZ's are here!!! [Re: PETE@BESTMACHINE] #14908
03/13/05 11:28 AM
03/13/05 11:28 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I do agree with this for sure......Although more choices in heads is good what we REALLY need is a good block alternative.
My take on why they came out with another head choice was stritcly to compete with Edelbrock. I am sure Edelbrock has taken some market share from Indy. And the fact that the exhast port was the main change seems to at least indicate that. Not to start anything here but I dont think they are overly concerned with Bulldog. It would not surprise me if you see the entire line revamped and some of the old choices eliminated all together.
Re: Indy 440-EZ's are here!!! [Re: PETE@BESTMACHINE] #14909
03/13/05 01:41 PM
03/13/05 01:41 PM
Think about this, .. the Indy EZ- CnC 325, they advertise flow
of 370 cfm @ 28" with a 2.19" valve.
If that is going on a 4.5" bore, .. it needs a valve of 2.30" or so,.
with that cross section & valve size it will EASLY go over
400 cfm ported & chamber work, .. race ported not a "budjet"
port.
The other thing, .. the low & small exhaust port, .. in an open
header car for drag racing isn't a bad thing, ..
Just my $0.20 worth.
I'm betting Dwyane will have some nice stuff from this head
for you guys, ..
Curtis
Re: Indy 440-EZ's are here!!! [Re: Al_Alguire] #14910
03/13/05 04:12 PM
03/13/05 04:12 PM
NC
440Jim Offline
440Jim  Offline
NC
I think the Indy EZ are an attempt to get some of the market share back from Edelbrock. I bet the Indy SR sales fell from the Edelbrock offering. Edelbrock still has the price beat, but now the EZ has more performance then Edelbrock and a price lower than the SR. Right now, it looks like the EZ will put the SR out of the market, or at least small sales volume. EZ or step up to the 440-1.
Re: Indy 440-EZ's are here!!! [Re: 440Jim] #14911
03/13/05 04:28 PM
03/13/05 04:28 PM
i looked at those EZ heads at the ICH show in indy. i was skeptical about the exhaust port and was surprised to see the flow numbers. the EZ is just a progression from the 440-1, the same as the sr's were. the real advantage is that they are 2 steps closer to a real bolt on. no need for external oiling on the small ports and they will bolt to existing exhaust systems. i have a friend who has sr's on a 64 belvedere and the header situation is a nusiance for a street car. on another note; i had a brief conversation with russ flagle. he stated that ICH is coming out with a six-pak manifold- carb set up for the big port heads. i believe its a 180 style with demon mech. carbs. this set-up will be availiable for hemi's also. would make a nice big cube street brawler.
