Re: Soooooo close to the 9's!!!!!
[Re: dizuster]
#1490177
08/27/13 10:45 AM
08/27/13 10:45 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Sorry about the hurt parts, but that's awesome! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dizuster]
#1490179
08/27/13 11:59 AM
08/27/13 11:59 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The lowest aftermarket ring and pinion made anymore is 3.55
just go to a taller tire the... or a (I'll whisper) a 9"
[Re: HMcCandless_Jr]
#1490181
08/27/13 01:01 PM
08/27/13 01:01 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Trans is coming out before it makes another pass. It's already killed one sprag (even with an LBA valve body), so hopefully the new super sprag held.
I actaully have a Dana, but it's a 3.55 which is the lowest.
I'm sort of at a cross road right now. The problem is that this thing already has it's tounge hanging out at the finish line because it's under cammed. So I could really put more cam in it, and use the 3.55 gear.
But the car only has a roll bar (no roll cage). So do I really need more power/traction being that I've already gone 10.08?
If so I could put the Dana in it, new cam, and a few more bars (plus window net), then get my license, etc... but in the end it's still a cast crank, stock rod, stock block motor... so how much harder am I really going to push this thing.
I'm debating right now what to do. I may sell the motor (and my '71 duster project), and build a new turbo hemi to really see how quick we can make this ol' heap. Or I may sell the whole car and build the new turbo Gen 3 hemi for my '71 duster that I have.
Just trying to think it through... for now it's just going to get the 2.76 and get back to racing the rest of this year with my ol' man (dvw).
[Re: dizuster]
#1490182
08/27/13 01:06 PM
08/27/13 01:06 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
There is a little more to the 9 sec club than the net and some bars. We have been getting our Duster ready, and did all that plus we need to add a gas pedal tow hook padding on all bars that your helmet could hit, solid rod for the throttle, still need a diaper, got all the trans sheild, -5SFI suit, bunch of stuff...So its adds cost, and it can make sitting in the car that much less enjoyable. Its a decision you have to make....Sweet little turbo motor you got there though. We have a 512 running the same ET..on pump gas.
[Re: dizuster]
#1490184
08/27/13 01:10 PM
08/27/13 01:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Scott... run what you have... going sub 10.0 isnt all that great.. it cost lots of money and a PITA for all of the crap... I had a lot more fun when I was running 10.0 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dizuster]
#1490187
08/27/13 02:24 PM
08/27/13 02:24 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Note to self, 8 3/4 is good to 10.09 in 3500 lb car......
Mopar to the bone!!!
[Re: Thumperdart]
#1490190
08/27/13 03:48 PM
08/27/13 03:48 PM
Mr.Yuck
Brookeville, Md
Been following your post and this is some awesome stuff for sure minus the carnage of course. Definately considered a power adder but not any time soon................keep up the good work.
Thump can you imagine what 100 more cubic inches could do???
[Re: dizuster]
#1490192
08/27/13 07:50 PM
08/27/13 07:50 PM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
Looks like you had some grip to break the pinion. BTW- regardless of whatever gear ratio you throw at it just keep in mind that it broke the pinion before any torque multiplication through the diff gears , meaning that any gear you use will be susceptible to this failure. I would look into a steel front planetary if you don't already have one. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: danbob]
#1490194
08/28/13 10:11 AM
08/28/13 10:11 AM
Mr.Yuck
Brookeville, Md
That thing is cool. Like Mr. P said, running sub 10s is a pain. Easy to maintain, fast and fun. You have the best of both worlds. If it were mine, a 9" would find its way in there. Good luck. P.S. What kind of gas mileage does it get??
the cool thing about it is that he can dial it up and run a few 9's then back it off and stay in the legal 10's or whatever your car will "tech" to.
