Indy 440-EZ's are here!!!
#14872
03/11/05 11:56 AM
03/11/05 11:56 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
UPS just dropped off two sets of the new Indy 440-EZ's. i have a set of the std and MW port opening versions here, and tonite i'll be posting some pics and OOTB flow numbers.
my first impression is....they look pretty nice. the castings are pretty smooth, and the intake ports have the pushrod bulge thats pretty prevelant on the SR heads basically gone on these heads. chambers are pretty much just like the SR heads. exhaust ports look pretty small compared to the SR's, as well as being in the std location.....it'll be interesting to see how well it flows. both ends of the heads are machined smooth, and "Indy" logo CNC'd into them.
i have a set of the CNC ported 295cc version on their way, and those should be here in a couple of days.
stay tuned....
Re: Indy 440-EZ's are here!!!
[Re: fast68plymouth]
#14873
03/11/05 12:38 PM
03/11/05 12:38 PM
Posts: 16,934 NC
440Jim
NC
... the intake ports have the pushrod bulge thats pretty prevelant on the SR heads basically gone on these heads.
I will stay tuned for some interesting numbers. How did they change the pushrod bulge? If the port is the same width and the pushrod (rockers) are in the same place, the only way would be to thin the wall at that point. But maybe the port is thinning at the pinch, or opening?
[Re: AdamR]
#14880
03/11/05 05:49 PM
03/11/05 05:49 PM
Posts: 791 mohnton pa
rva
super gas
super gas
mohnton pa
Are those the heads for Rudy's Barracuda ?
mine are the ones that flow the best dwayne you picked the CNC440-EZ for me didn't you did you get the big Dom and msd in the mail, Thanks talk soon.
#14882
03/11/05 09:23 PM
03/11/05 09:23 PM
fast68plymouth
So. Burlington, Vt.
left my camera at work....so no pics tonite....but i have the important stuff
the two heads tested are a 440EZ, and a 440EZ-1.
the EZ-1 has the intake port opening CNC'd out to the MW size, and the bowls are cleaned up with some CNC work as well.
i can see with these heads that the emphasis on where the improvments should be focused has shifted from the intake side of the head, to the exhaust side.
the exhaust port is rather small, but does flow pretty well for its size.
with some additional porting i think it will come around pretty well.....but for the higher HP/bigger cube combos, i think a dual pattern cam will be in order.
when i talked with Russ at ICH about these heads he was saying how the intake ports were basically just SR ports.
well.....thats not exactly correct.
its more like..... ported SR ports.
the unported SR short turn is basically a cliff thats slanted towards the center of the bore.
these new heads have a more modern look to them. the floor is much more convex, and the short turn is a big, long radius.
the pushrod bulge has been basically removed completely, and the as cast width is 1.060(on the non-MW version).
anyway.....you guys just wanna see the numbers....so here they are.
tested on a 4.375 bore:
440EZ(std port opening)
lift-----I/E
.100--63.4/57.6
.200-135.5/103.3
.300-201.2/143.3
.400-253.1/176.2
.450-270.7/188.1
.500-286.6/196.2
.550-297.3/201.4
.600-302.7/205.4
.650-306.3/205.4
.700-309.9/204.1
440EZ-1(MW opening, CNC bowls)
lift-----I/E
.100--65.4/55.1
.200-140.9/102.7
.300-209.7/138.1
.400-265.9/178.2
.450-290.0/193.0
.500-308.1/202.7
.550-324.2/211.9
.600-333.1/218.4
.650-340.3/223.7
.700-343.9/227.6
the low lift flow is a little weak on the std EZ, but i think a little tweek of the valve job and a back cut to the valve would perk that up some.
the 440EZ-1 has a killer intake port....rock steady at .700 lift....nice and quiet....good flow.
this is a very nice port for an OOTB head(and puts an OOTB 440-1 port to shame).
this head will be an easy 500ci/700hp piece with some work done on the exhaust side.
Rudy's getting the CNC295 version of these, which i hope to have on hand next week....and will get on the flow bench when they arrive.
on a side note....i have 2 sets of Bulldogs in the shop as well.
one set is the last version prior to them raising the intake ports, and then i have a new set with the raised intake ports.
i'll try and get some numbers on them to compare in the next few days.
the new raised runner version is a direct competitor to this new ICH 440EZ head.
my guess is, it will be pretty much like the BD vs SR thing was when the BD's first came out. the low/mid lift numbers will be better than the ICH heads, but the ICH heads will be better up top(thats my prediction anyway).
anyway.....my overall impression is.....its nice when a new product is like what the advertisements claim them to be.
these are definately going to be a nice step up from the E head for guys wanting to build 500ci combos, and dont want to replace their expensive headers.
#14883
03/11/05 09:45 PM
03/11/05 09:45 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Thanks for the report Dwayne ![](/ubbthreads/images/graemlins/thumbs.gif) Looks like Indy has a winner with these new castings. ![](/ubbthreads/images/graemlins/smoke.gif) They should sell a lot of them. What were the chamber/port volumes on the EZ-1's ? Ron
[Re: firefighter3931]
#14885
03/11/05 09:56 PM
03/11/05 09:56 PM
fast68plymouth
So. Burlington, Vt.
Ron,
too busy in the shop to do much "investigative measuring", but the advertised numbers are 270/275 CC's for the intake runners, and they are available with either the std ICH heart shaped 75cc chamber, or an 80cc version, in which they do the same thing Ebrock did for the 84cc to 88cc deal on their heads.
AAR, these two versions of the EZ's are somewhat of a "stock replacement" head.
they dont use external oiling(the next two bigger versions do), they dont need special headers, they require longer pushrods, they can use any std type BB rocker arms.
they do need different head bolts(same as the SR and 440-1), and have raised intake ports so the ICH valley cover can be used instead of the valley pan gasket.
the heads themselves are slightly less money than the SR's.
the basic "kit" comes with:
-assembled heads
-pushrod kit
-valley cover
-intake gaskets
-head bolts
#14886
03/11/05 09:58 PM
03/11/05 09:58 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
When did BD raise the intake port and how can I tell which I have?
Thanks Dwayne
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
#14888
03/11/05 11:07 PM
03/11/05 11:07 PM
Posts: 4,424 Montgomery, AL
v8440
Montgomery, AL
Dwayne, you're scaring me here with those flow #'s on the EZ-1. It's looking like they're better than the SR's I ordered, at least on the intake. What's the deal?
Exactly 610 posts on old board, first whacked post in the history of this one!
Funny moparts quote from Waginator:
"*If you want your package lost, like bermuda triangle lost, use DHL (formerly airborne)
*if you want it to get there but destroyed, use UPS."
[Re: v8440]
#14889
03/12/05 12:07 AM
03/12/05 12:07 AM
Dwayne,
Nice post, .. thanks for the info.
It looks like these will be the heads to have over the SR's. I have SR's flowing 362 @ .700" FULLY ported, .. it looks like the MW EZ's will get past that fully ported, .. do you think??
Again, .. nice info, .. !
Curtis
#14891
03/12/05 09:05 AM
03/12/05 09:05 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
lift-----I/E
.100--63.4/57.6
.200-135.5/103.3
.300-201.2/143.3
.400-253.1/176.2
.450-270.7/188.1
.500-286.6/196.2
.550-297.3/201.4
.600-302.7/205.4
.650-306.3/205.4
.700-309.9/204.1
lift-----I/E
.100--65.4/55.1
.200-140.9/102.7
.300-209.7/138.1
.400-265.9/178.2
.450-290.0/193.0
.500-308.1/202.7
.550-324.2/211.9
.600-333.1/218.4
.650-340.3/223.7
.700-343.9/227.6
int .100 74 - 76 ex 50 - 58
int .200 149 - 154 ex 104 - 117
int .300 210 - 223 ex 145 - 170
int .400 263 - 278 ex 180 - 209
int .500 301 - 328 ex 210 - 245
int .600 311 - 363 ex 237 - 270
int .700 313 - 368 ex 250 - 287
int .800 306 - 378 ex 257 - 301
First set of numbers is with a "supermod" bowl and chamber job by
Indy, second after installing 2.25 intakes and porting by R&J out of Iowa.
These are my 440-1 ported heads, purchased in 1998, for referance. I am curious what you think the performance differance will be between the two versions of each head Dwayne?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
