Page 11 of 14 1 2 9 10 11 12 13 14
Re: '71 Demon Project Build [Re: VITC_GTX] #148884
04/08/10 12:39 AM
04/08/10 12:39 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I'd have to say that painting it like that would make the scoop really stand out... if thats what you want? If you're going to do it that way, make sure to replicate the blackout stripe look with a 1/4 stripe around the larger areas. You can always get a roll of 1/4" wide tape and experiment with ideas before you paint it.
Re: '71 Demon Project Build [Re: VITC_GTX] #148885
04/08/10 10:21 PM
04/08/10 10:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Sizzler...
Nautilus Racing-
Re: '71 Demon Project Build [Re: Chris2581] #148886
04/10/10 02:41 PM
04/10/10 02:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd go with the Sizzler striping, I'd paint right over the 6 pack scoop like it wasn't even there, sometimes a subtle blend is better than something to make it stand out, especially on a mostly stock looking car. You don't want that scoop to stick out like a sore thumb, you want it to complete a total "look".....and don't forget the body color grille!
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148887
04/11/10 08:17 PM
04/11/10 08:17 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
You guys are talking me into the Sizzler paint scheme. I was planing on having the grill stock color, black/silver, not body color. I thought the car will have enough green already without adding to it.
Cleaned the heater box and replaced the heater core today. I'll post pics later this week. Car is scheduled for paint next weekend.
Re: '71 Demon Project Build [Re: VITC_GTX] #148888
04/16/10 11:18 PM
04/16/10 11:18 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I washed the entire car and will be putting it on the trailer tomorrow morning at 0700 to take to the paint booth. I'll post some pics tomorrow evening...
Re: '71 Demon Project Build [Re: VITC_GTX] #148889
04/17/10 05:04 AM
04/17/10 05:04 AM
8
88_mopar Offline
88_mopar  Offline
Well I hope I'm not too late in saying this, but ppg recommends that base coat should be applied over DP within 7 days of being sprayed. Meaning, after you spray DP, you have a 7 day window to apply base. If you are passed your 7 day window, it's recommended that you apply another coat of dp before paint. Not sure if you knew this but dp is also a sealer. When mixed 2:1 (dp:402 or 401) it's a primer sealer, when mixed 4:2:1 (dp:402 or 401: reducer) it's considered a sealer. The reducer helps with flow and it lays on very smooth.
So I would suggest before you spray base, spray one more coat of reduced dp. You shouldn't have to sand it if applied properly and it'll cover those small bare metal spots you mentioned.
Also ppg says you only have 24 hours after applying basecoat to apply clearcoat, assuming you're using the deltron line.
Could you get by without another coat of dp, yea probably. But if I were you i wouldn't chance it.
Re: '71 Demon Project Build [Re: VITC_GTX] #148890
04/17/10 05:58 AM
04/17/10 05:58 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
That's how I would paint it..leave the grill stock,but use the Sizzler hood treatment
Nautilus Racing-
Re: '71 Demon Project Build (Now in color!!) [Re: VITC_GTX] #148891
04/17/10 08:24 PM
04/17/10 08:24 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
OK, it's finally in color. I took it over to the paint booth this morning. Seemed to turn out nice. My friend painted it and he was very happy with the results, so am I. I go back tomorrow morning to pick it up and bring it home. The wet sanding will probably start Monday or Tuesday.
Getting ready to go into the booth.
In the booth masked up.
Three hours later...
That is A LOT of green!!!
Re: '71 Demon Project Build [Re: NV69B7RR] #148892
04/17/10 08:57 PM
04/17/10 08:57 PM
Northwest Alabama
JAAK Offline
JAAK  Offline
Northwest Alabama
WoooooooooooHooooooooo!!!!!!!!!
That looks great!
Jason
69 Charger RT 440/Auto. 68 Charger
Re: '71 Demon Project Build [Re: JAAK] #148893
04/17/10 09:25 PM
04/17/10 09:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
NICE! Can't wait to see the Sizzler Striping! You should seriously consider painting the grill as well to complete the Sizzler look, it would look killer!
Re: '71 Demon Project Build [Re: ScottSmith_Harms] #148894
04/17/10 11:56 PM
04/17/10 11:56 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Re: '71 Demon Project Build [Re: NV69B7RR] #148895
04/18/10 01:35 PM
04/18/10 01:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Looks great!
Re: '71 Demon Project Build (Now in color!!) [Re: VITC_GTX] #148896
04/18/10 09:09 PM
04/18/10 09:09 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I went and picked up the car this morning. Dropped it off at home and went rattlesnake hunting for the afternoon (the weather was just right!). I just got back and took the car off the trailer and put it in the shop. The paint came out great. It layed pretty flat and shouldn't be to difficult to cut and buff. My friend is going to come over tomorrow and start on it.
Enjoy...
Coming out of the booth.
Finally home on the trailer.
Back in the shop.
Paint layed down pretty nicely.
Re: '71 Demon Project Build (Now in color!!) [Re: VITC_GTX] #148897
04/18/10 09:42 PM
04/18/10 09:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Looks awesome!
Re: '71 Demon Project Build (Now in color!!) [Re: OzHemi] #148898
04/18/10 11:26 PM
04/18/10 11:26 PM
Rockford,IL
71Polara383 Offline
71Polara383  Offline
Rockford,IL
Looks Amazing. Wanna do mine next???
Re: '71 Demon Project Build (Now in color!!) [Re: 71Polara383] #148899
04/19/10 01:06 AM
04/19/10 01:06 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the kind words.
I don't think you want me doing your car. I did all the tear down, metal work and most of the filler work but my friend did the block sanding and painting, he's really good at it. I'm not sure you would want me
Also, I was planning on being at this stage within 6 months...it's taken me 16 months
Re: '71 Demon Project Build (Now in color!!) [Re: VITC_GTX] #148900
04/19/10 08:10 AM
04/19/10 08:10 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Give yourself credit you took the car a part and built a racecar and raced during that time also.
Re: '71 Demon Project Build (Now in color!!) [Re: moparpollack] #148901
04/19/10 08:20 AM
04/19/10 08:20 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Looks really good! Looking forward to reassembly now.
65 Barracuda
70 Challenger
Re: '71 Demon Project Build (Now in color!!) [Re: moparpollack] #148902
04/19/10 11:29 AM
04/19/10 11:29 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the pick-me-up
I have been a little busy lately
Re: '71 Demon Project Build (Now in color!!) [Re: jrwoodjoe] #148903
04/19/10 11:30 AM
04/19/10 11:30 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks.
I am looking forward to this car being done!!
