Re: my E-85 experience.
[Re: MR_P_BODY]
#1488401
08/26/13 01:02 PM
08/26/13 01:02 PM
dartman366
Mt. Vernon, Ohio
buy an A/F guage, put in an O2 sensor and forget about "guessing" what it wants
maybe santa claus is listening.
Forget the A/F meter on a race car... you know to tune for the fastest MPH... then if you want you can take a A/F reading... there is no magic number to tune to
If I were to do anything I think I would concider a pyrometer and tune by egt, but untill then I am going to tune by coolant temp rise and like you said,,MPH, if I were running the snot out of it every weekend then I may be more enclined to get into the o2 and A/F sensors and such, but that just not in the budget at this time.
[Re: dartman366]
#1488402
08/26/13 05:27 PM
08/26/13 05:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill...when you get it tuned in for best MPH you will most likely see a 20 degree temp increase in the 1/4
[Re: ajcasini]
#1488404
08/26/13 05:42 PM
08/26/13 05:42 PM
MR_P_BODY
Mr P most of the tuning i have done with an O2 watching H2O temp shows 8-12* to be the right tune. On the combos I have logged O2 on this puts lambda at .80-.82 which is where you want to be for a quick consistent tune.
What temp do you leave at... I think I was leaving a bit too cold... I should have been near 180-185
[Re: ajcasini]
#1488406
08/26/13 06:26 PM
08/26/13 06:26 PM
MR_P_BODY
Most cars like 170. I have run mine as low 160 and high as 180 with no real performance change.
Normal runs in the heat of summer leave 170 go through a tick above 180. In the spring and call leave at 170 go through a tick below 180.
Thats why I said 20* increase... I was leaving at 160* and seen 180* at the end.. most of the E-85 guys I've talked with found that they made more power leaving at a 180* temp... some even at 185*... I never tried the higher temps myself but plan on trying it
[Re: ajcasini]
#1488408
08/26/13 07:17 PM
08/26/13 07:17 PM
Triple Threat
Renton Washington
I'm usually doing my burnout without the fan off to bring it up to 165ish. I've never seen an increase in power running hotter or colder than that.
[Re: VernMotor]
#1488412
08/26/13 11:23 PM
08/26/13 11:23 PM
MR_P_BODY
Been tuning cars by the seat of my pants for 30 years. works just fine
I have all of the fancy dandle stuff but I use it about 10% of the time... my A/F meter is used for cruise A/F only.. I tune the race car on the MPH... I never seen the need for it on the race car... I set the idle for where it idles best and WOT on the MPG
