Page 16 of 20 1 2 14 15 16 17 18 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: RUNCHARGER] #1488033
07/14/14 10:00 AM
07/14/14 10:00 AM
West Palm Beach, Florida
Copper Dart Offline OP
Thanks guys, I too hope to see it in person soon;) lol
I do wish he would have separated the pipes aft of the "X" a bit.
If it causes trouble, it can be adjusted and the mufflers are serviceable without cutting anything.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488034
07/21/14 08:08 PM
07/21/14 08:08 PM
Just a little progress.
installed the 3/8 aluminum fuel tube today.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488035
07/21/14 08:10 PM
07/21/14 08:10 PM
its easy to flare the ends for rubber fuel lines with a brake line flare tool.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488036
07/21/14 08:14 PM
07/21/14 08:14 PM
Patience when bending the lines is very helpful.
I was able to remove the exhaust from the muffler back on the right side to ease the fitting the fuel tube.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488037
07/21/14 08:18 PM
07/21/14 08:18 PM
i installed a Wix filter #33033 (3/8" inlet and outlet) just to keep things cleaner in the new fuel system.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488038
07/21/14 08:24 PM
07/21/14 08:24 PM
these clamps work great with self tapping screws to hold the tube secure. I'm sure they will help prevent the tube from springing a leak later and maybe keep things quieter too.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488039
07/21/14 08:27 PM
07/21/14 08:27 PM
I think these custom mufflers might be a bit loud. They are chambered but not much.
I hope to get it running soon and hear them.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488040
07/23/14 12:21 PM
07/23/14 12:21 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Looking good, Copper Dart!
I was just curious, when you undercoated the new fuel tank, did you wipe off the factory zinc coating first? I just bought a new fuel tank for my 69 Satellite wagon and I'm interested in undercoating the top of the tank and clearing the bottom of the tank, but its covered in that zinc coating that they use at the factory and I'm not sure what to remove it with...
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Sneke_Eyez] #1488041
07/23/14 04:23 PM
07/23/14 04:23 PM
Thanks,
To answer your question, I'm not sure you can just wipe off a Zinc coating. I think it's more like a melted coating on the metal kinda like galvanizing or solder.
I washed the upper tank surface with a cleaner (acetone) and lightly scotchbrited it before coating.
I haven't considered clear coating the underside. Might just do it too, good idea.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1488042
07/23/14 05:14 PM
07/23/14 05:14 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Yeah, I wasn't sure what verb to use "wipe" off, "clean" off, I wasn't sure because I've never owned a gas tank new enough to need this done to it before.
Do you remember what kind of cleaner you used? I was considering trying out some acetone and a rag and scotchbrite. I want to protect the tank as much as I can on top while keeping it "new" looking on the bottom.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Sneke_Eyez] #1488043
07/24/14 12:14 AM
07/24/14 12:14 AM
houston BC canada
fez340 Offline
fez340  Offline
houston BC canada
just finished reading about your build so far. awesome work! gives me some motivation to work on mine keep up the good work
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2147611
09/04/16 10:32 PM
09/04/16 10:32 PM
sorry for the long delay in updating the build.
life has a way of creating roadblocks and bumps to side track attention to our toys.
we finally got around to test fit the wheels to see if we measured everything correctly in the mini-tubbing and axle narrowing.
i am happy to say, following the cliche "measure twice, cut once" was well worth the effort!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2147618
09/04/16 10:38 PM
09/04/16 10:38 PM
there is ample clearance all around for different tire sizes/brands. moving the axle back adds a lot without having to cut any of the wheel opening. it's the look i was shooting for without butchering the outer body panels. boogie
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2147729
09/05/16 01:07 AM
09/05/16 01:07 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Those wheels look great, look really good with your paint and stripe.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2147730
09/05/16 01:08 AM
09/05/16 01:08 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Those wheels look great, especially with your paint and stripe.
Wow I didn't know I stuttered
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2163527
09/28/16 11:03 AM
09/28/16 11:03 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Love to see a Dart with Fat tires!
Keep posting, can't wait to see it finished
Looking for affordable 72-74 Cuda parts
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: rocksmopar] #2747044
02/27/20 12:42 PM
02/27/20 12:42 PM
Hey guys and girls, sorry for the long time since but life, health and job changes and I find myself considering selling my project.
I’m not sure how to go about finding it a new home. Any questions please drop me a text561.three89.7four25
Thanks again
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2747046
02/27/20 12:44 PM
02/27/20 12:44 PM
Yes I am considering selling my 70 dart swinger project
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2747213
02/27/20 09:50 PM
02/27/20 09:50 PM
Superfreak
Superfreak
Sorry to here but like all things, "ya gota do what ya gota do"
Good luck with the sale and hopefully it goes to a good home.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: ] #2749262
03/05/20 01:31 PM
03/05/20 01:31 PM
Thanks. Are you familiar with my build ?
If so, may I ask how would you begin to figure a fair price to ask?
Thanks again. Ricky
Mom.
Ricky Valdes
