Page 12 of 20 1 2 10 11 12 13 14 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487953
10/19/13 10:19 PM
10/19/13 10:19 PM
West Palm Beach, Florida
Copper Dart Offline OP
I was trying to avoid removing all of the Factory Black Tar-like seam sealer stuff but it doesn't dress well.
No big deal, just more time spent scraping and wire-brushing to get it right before paint.
Opinions anyone? I am new at this and could use some pointers.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487954
10/19/13 11:25 PM
10/19/13 11:25 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Liquid nails is cheap and easy if you are not doing an OEM restoration. I spent $35 on a can of seam sealer and it flaked off, the liquid nails is permanent.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: moparpollack] #1487955
10/20/13 08:58 AM
10/20/13 08:58 AM
When dry, it's not flexable right?
I should have asked before heading to the Auto Body and Paint store!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487956
10/20/13 08:38 PM
10/20/13 08:38 PM
1969proDart Offline
1969proDart  Offline
When you use Seam Sealer I recommend having some Acetone handy!
Thanks Juan.
No problem Ricky! Glad it helped, looks great! :
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: 1969proDart] #1487957
10/21/13 05:57 PM
10/21/13 05:57 PM
Dutchman Axles ordered!
Thanks, Doctor Diff
aprox 23.5"
I still have to install the rear Super Stock spring hangers and order the shocks.
is a sale going on at Jegs or summit?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487958
10/21/13 08:27 PM
10/21/13 08:27 PM
1969proDart Offline
1969proDart  Offline
I started my thread!! check it out Ricky. im tired so ill post more progress tomorrow!
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: 1969proDart] #1487959
10/21/13 11:16 PM
10/21/13 11:16 PM
Juan
I look forward to your build.
, I have that '69 notchback for parts so don't forget.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487960
10/24/13 08:17 PM
10/24/13 08:17 PM
1969proDart Offline
1969proDart  Offline
Whoop whoop awesome, if I find anything I need I'll keep you posted. At this point I probably need cosmetics. Which I'll probably buy new. Headliner, windlace, wheel well chrome trim, a pillar mouldings...etc....
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: 1969proDart] #1487961
11/12/13 04:32 PM
11/12/13 04:32 PM
I've been hand sanding the trunk area for a week and I have discovered I DON'T LIKE SANDING!
I don't know if I will survive this part of the project, I'd rather be working on the Rear Spring Hanger installation.
I may come back to address the trunk later.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487962
11/13/13 05:05 PM
11/13/13 05:05 PM
1969proDart Offline
1969proDart  Offline
Yea I still have to do my whole car, considering on just letting the body shop do everything. I've gotten far in my build, tubs doctordiff axles etc.. haven't had time to post pics. maybe tonight.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: 1969proDart] #1487963
12/07/13 11:41 AM
12/07/13 11:41 AM
Drilling the Rear Spring Hanger holes to 1 1/8" is not going to be easy. No room between the spare tire well and the inside frame rail, I am only able to drill from the outside-in just fit between the lower quarter panel to frame rail. I rented an Angle Drill from my local TrueValue Hardware Store and I found my new Best Friend!
A Monster Step Drill Bit!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487964
12/07/13 12:01 PM
12/07/13 12:01 PM
Its very easy to open the outboard side with the step drill bit but you have to remember to stop at the correct diameter
Once I had the outboard hole done, I used a Die Grinder through the outboard hole to enlarge the inboard side of the frame rail to fit the shackle bushing.
Is it me or does Murphy visit everyone?
The inboard frame rail is double thick!
So much fun as you grind to be showered by Hot Sharp metal slivers! OH THE JOY
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487965
12/07/13 09:20 PM
12/07/13 09:20 PM
The rear shackle tubes burned in and moving on to the narrowed diff assembly.
I need to mock up the spring pad placement and set the installed pinion angle.
I need to find out what pinion angle is best for my set-up.
Should I try for the stock degree angle or maybe a little down from stock angle?
I'm installing new Mopar SuperStock springs from Mancini Racing.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487966
12/07/13 09:22 PM
12/07/13 09:22 PM
Thanks Doctor Diff!
The Dutchmans fit perfectly!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487967
12/08/13 09:01 PM
12/08/13 09:01 PM
more progress on the Narrowed Rear install.
Installing the shackle bushings at the rear leaf spring eye's had me wanting to give up! The eyelet is too small to fit the rubber bushing in and the shackle shaft. work the bushing in and then try to press the shackle shaft in. IT DOES'NT FIT! Called my brother "Model Maker" and he said why don't you just mill them down a little? ......Hey, that's exactly what I was thinking
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487968
12/08/13 09:06 PM
12/08/13 09:06 PM
Look at the difference in the Stock "A" body 8.75 and the narrowed.
I have to keep the stock one complete while the mods are done so I can roll the car indoors during the week. I'm getting really good at R&R of the rear assembly
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487969
12/08/13 09:12 PM
12/08/13 09:12 PM
Mocked up, adjusted pinion angle and measured 20 times. Henry and I both gave it the thumbs up and I tack welded the spring perches on.
Now to disassemble it once more for final burning in of the perches and sand blasting/cleaning and painting.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487970
12/08/13 09:19 PM
12/08/13 09:19 PM
Perfect fit and sidewall clearance. No, those aren't the wheels, just for fitment.
Another view.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487971
12/08/13 09:24 PM
12/08/13 09:24 PM
I am ready to take it to Henry's and use his MillerMatic 180
My Lincoln ProMig might do a good job but it would be at it's amperage limit and I don't want to chance it, besides sand blasting is messy and I would rather mess his shop up than mine
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487972
12/23/13 12:19 AM
12/23/13 12:19 AM
While I have the rear assembly out I might as well finish the undercoating and sealing of the wheel tubs.
I modified my sand blaster gun to spray Rustolem Truck Bedliner coating. It worked great except my arms got tired of holding a gallon can up and following around the spray gun. Maybe a longer suction hose would have been better.
Mom.
Ricky Valdes
