Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build
[Re: RUNCHARGER]
#1487935
09/22/13 11:41 PM
09/22/13 11:41 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Thanks First time too. I wouldn't have attempted it without the support of you Moparts members answering my stupid questions along the way Thanks Moparts
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1487938
10/05/13 10:49 PM
10/05/13 10:49 PM
Copper Dart
Both tubs are installed. I want to undercote the wheel wells to somewhat match the factory applied sound deaden-er coating. Ackie Swarez <SP> delivered the custom narrowed housing today! More bad news, Doctor Diff said the housing is too narrow for his stock of forgings..... Add another $100. +/- to the build!
[Re: Copper Dart]
#1487939
10/05/13 10:55 PM
10/05/13 10:55 PM
Copper Dart
everything is over budget! My advise....Add 50% to everything and you might be within budget! I need to check my life insurance policy before undertaking the interior!
[Re: Copper Dart]
#1487940
10/12/13 01:32 PM
10/12/13 01:32 PM
Posts: 375 An Island in the Pacific N.W.
moopa
Great work and very inspiring. Thanks for the updates, and keep 'em coming!
Mark
2015 TorRed Challenger Hellcat,A8
2013 Plum Crazy Challenger SRT8,6 Spd
2013 Black Challenger R/T Classic,auto
(2)72 Satellites, one on hold,one under resto on the rotisserie.
[Re: moopa]
#1487941
10/13/13 04:10 PM
10/13/13 04:10 PM
Copper Dart
housing length 44 1/8" Calling Doctor Diff!
[Re: Copper Dart]
#1487942
10/18/13 10:27 PM
10/18/13 10:27 PM
Copper Dart
I was able to finish the radiator install today! Feels good when you accomplish a task. I drilled the 4 mounting holes and test fit again before welding the factory nut-serts in place.
[Re: Copper Dart]
#1487943
10/18/13 10:29 PM
10/18/13 10:29 PM
Copper Dart
the right side was a bit easier to do.
[Re: Copper Dart]
#1487944
10/18/13 10:35 PM
10/18/13 10:35 PM
Copper Dart
i hope i dont have to remove this anytime soon, its a tight fit and things have to be done in a certain order to get them to fit.
[Re: Copper Dart]
#1487945
10/18/13 10:39 PM
10/18/13 10:39 PM
Copper Dart
I was concerned that the fan blade was going to be too deep into the shroud but it came out just perfect!
[Re: Copper Dart]
#1487946
10/18/13 10:45 PM
10/18/13 10:45 PM
Copper Dart
I may have been able to fit a 19" fan blade but i think the 18" will do just fine. the radiator hoses needed just a little trimming to fit. the upper #70624 i trimmed about 1" from the radiator end only. the lower #70592 i trimmed about 1/2" from both ends to clear the strut rod area.
[Re: Copper Dart]
#1487948
10/19/13 10:01 PM
10/19/13 10:01 PM
Copper Dart
I'm blown away, after wire-brushing and grinding of the welds, as to how the Ospho destroyed what little rust was left . Caution: Don't get it on the concrete floors or painted areas! Here's a close up of the treated metal before using the Metal Etching Primer. Clean the area first then spray on the Ospho and wait maybe 20 min, then wash off with a very damp towel/rag and voila! I've read that Ospho is an Excellent primer too!
[Re: Copper Dart]
#1487949
10/19/13 10:05 PM
10/19/13 10:05 PM
Copper Dart
Metal Etching Primer : Done. I was told this is a must to protect the raw metals and welds. What do I know? I'm just following instructions.
[Re: Copper Dart]
#1487950
10/19/13 10:07 PM
10/19/13 10:07 PM
Copper Dart
after this dries i have to get out the sand paper and pay close attention to the detail.
[Re: Copper Dart]
#1487951
10/19/13 10:10 PM
10/19/13 10:10 PM
Copper Dart
When you use Seam Sealer I recommend having some Acetone handy! Thanks Juan.
