Page 6 of 20 1 2 4 5 6 7 8 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487833
09/01/13 08:02 PM
09/01/13 08:02 PM
West Palm Beach, Florida
Copper Dart Offline OP
the front section adjusted perfectly to stay inline with the forward frame.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487834
09/01/13 08:06 PM
09/01/13 08:06 PM
this is a look from behind to show the slight angle change to meet with the forward frame section. might be hard to see.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487835
09/01/13 08:07 PM
09/01/13 08:07 PM
maybe this one is a better picture?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487836
09/01/13 08:16 PM
09/01/13 08:16 PM
just in case someone wanted to know the parking brake cable holes location/measurements.
Don't laugh at my chicken scratch
Holes are both 1/2" by 4"
and both are 1" from the bottom.
Out side hole (measured from the forward most end of the sub frame connector) starts at 4" and the inside starts at 16".
Pay Pal gladly accepted
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487837
09/01/13 08:22 PM
09/01/13 08:22 PM
i will be attempting the passenger side weld in tomorrow.
P.S. The sprinkler guy never showed again. Said they would be here this morning to finish the job. Only thing left to do is back fill, install the heads and adjust them, may be 3 hours work!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: hunterstroble] #1487838
09/01/13 08:47 PM
09/01/13 08:47 PM
The Metal chrome Mopar Performance steel valve covers clear nicely Because of the tapered edges. Our valve cover goes on and off easy.
Does it clear the A/C blower motor?
I understand that the Heater only setup is smaller and at a slightly different position. I do eventually want to use the A/C.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487839
09/02/13 03:50 PM
09/02/13 03:50 PM
Just a little FIY, you can put multiple pics and text in one post........ might be easier. Just a thought. Looks good so far. So you were saying that the ball joint was actually in upside down.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: ] #1487840
09/02/13 07:38 PM
09/02/13 07:38 PM
Thanks, I'll have to learn how to post multiple pictures on the same post.
Any easy lesson you would like to share with a computer illiterate?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487841
09/02/13 08:50 PM
09/02/13 08:50 PM
drivers side connector with the E-brake cable passed through.
i'm going to try to figure out how to post more than one pic per post.
i must admit I'm allot more confident working on the car than this computer.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487842
09/02/13 08:54 PM
09/02/13 08:54 PM
Nope, the computer is still smarter than me
still only able to post one picture per.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487843
09/02/13 08:58 PM
09/02/13 08:58 PM
Does anyone know what this little tab is for? Its on the rear section of the frame connectors, both inside and outside, left and right.
My luck, it will be something important!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487844
09/02/13 09:00 PM
09/02/13 09:00 PM
passenger outboard view.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487845
09/02/13 09:05 PM
09/02/13 09:05 PM
Both Mancini Sub-Frame Connectors added to the Completed List!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487846
09/02/13 09:05 PM
09/02/13 09:05 PM
Passenger side
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487847
09/02/13 09:07 PM
09/02/13 09:07 PM
Don't they look kinda big?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487848
09/02/13 09:14 PM
09/02/13 09:14 PM
By popular vote, I'm going start on the Mini tubs next.
PLEASE, you guys that have done this before, any pointers, tricks or CAUTIONS! if you can
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487849
09/03/13 11:51 AM
09/03/13 11:51 AM
I guess I'm on my own. Other than some consultation from my brother, no one has chimed in. I am a bit nervous and don't want to screw things up.
I have to remind myself that its my car and I can fix it if I do screw it up.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487850
09/03/13 02:13 PM
09/03/13 02:13 PM
Drop the rear
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487851
09/03/13 02:24 PM
09/03/13 02:24 PM
The Car was preserved perfectly from day one with I think Zebart Rustproofing. I love the results of the protection, I bet they used 50.lbs of tar undercoating.
Chipping it off is about to kick my rear! I'm feeling my years quite clearly.
Here are some proposed cut lines. I am going to think it over a bit. I already cut the trunk hinge brackets off the insides of the tubs and I drilled out the spot welds for the diagonal braces.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487852
09/03/13 02:25 PM
09/03/13 02:25 PM
from the inside
Mom.
Ricky Valdes
