Page 7 of 20 1 2 5 6 7 8 9 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487853
09/03/13 02:26 PM
09/03/13 02:26 PM
West Palm Beach, Florida
Copper Dart Offline OP
passenger side from underneath
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487854
09/03/13 05:34 PM
09/03/13 05:34 PM
Just a few starter slots cut with a sizz-wheel and the rest is done with a Milwaukee Super Sawsall. One long blade (for the frame rail arch) and one small blade for everything else.
Nice and slow, take your time and it cuts like butter with some shiny silvery snowflakes that burn!
This is my first time attempting the "ELUSIVE" Mini Tub Mod
I think removing it may be the easy part.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487855
09/03/13 05:38 PM
09/03/13 05:38 PM
I will post the areas that I cut first with the Sizz-wheel just for the books.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487856
09/03/13 09:36 PM
09/03/13 09:36 PM
**Make sure you are wearing Eye Protection at all times**
A trip to the ER doesn't get the project done quicker. Besides, if you cant open your Eyes, how can you see your wonderful work? Duh!
I made sharp punch dimples at the corners for reference and some along strategic points to help guide me while cutting. To get started, I just cut enough with the sizz-wheel to fit the Sawsall blade through. The forward section required three starter cuts/slots.
The lower vertical line cut starts up from the bottom pinch weld area, no need for a starter cut. I kept the Seat Back Lower Tab in the stock area with that staggered cut rather than having to weld a new tab on.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487857
09/03/13 09:47 PM
09/03/13 09:47 PM
The rearward section required four starter cuts/slots. The far right one (kinda hard to see) is for the edge of the frame rail arch. Again, the vertical cut (not marked with and arrow) that splits the center of the tub starts from the bottom pinch weld area up.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487858
09/03/13 10:06 PM
09/03/13 10:06 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Hey better late than never,right?
http://www.bigblockdart.com/techpages/wells.shtml
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487859
09/03/13 10:12 PM
09/03/13 10:12 PM
I have a Bucket full of UNDERCOATING! Miserable job chipping it off. Major PITA! You cant see the metal under 1/4" of rock hard undercoating chip chip chip, tap tap tap, scrape scrape scrape till your arms fall off, Oh and don't forget that every ten taps you miss the chisel and strike your VERY sore knuckle.
So how does it go "chip chip chip, tap tap tap, scrape scrape scrape thud #*&$#$!!!chip chip chip, tap tap tap, scrape scrape scrape thud #*&$#$!!! Rinse and Repeat
Drivers side out!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487860
09/03/13 10:19 PM
09/03/13 10:19 PM
I guess I'de rather suffer through scraping the undercoat than seeing allot of rust or even worst the dreaded cancer/rot!
The frame rail wasn't so bad, it's pretty flat and you don't have to scrape over your head like in the upper part of the wheel well.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: crowbait] #1487861
09/03/13 10:25 PM
09/03/13 10:25 PM
Great link.
Thanks! Pretty close to what I did. Sure make me feel better to see it done by a pro.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487862
09/03/13 10:28 PM
09/03/13 10:28 PM
More pictures
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487863
09/03/13 10:29 PM
09/03/13 10:29 PM
All this was done for what? Clearance!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487864
09/03/13 10:30 PM
09/03/13 10:30 PM
Measured at about the center of the wheel opening.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487865
09/03/13 10:31 PM
09/03/13 10:31 PM
and the back
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487866
09/03/13 10:33 PM
09/03/13 10:33 PM
Passengers side almost exactly the same!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487867
09/03/13 10:38 PM
09/03/13 10:38 PM
I couldn't wait to try my little "Fatty Fat Fats"
I know I know, its not that big but it still looks Bad Azz!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487868
09/03/13 10:39 PM
09/03/13 10:39 PM
check out this view.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487869
09/03/13 10:42 PM
09/03/13 10:42 PM
The diameter looks perfect but I don't expect to have it that low in the rear. Great for measurements.
Here's more.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487870
09/03/13 10:44 PM
09/03/13 10:44 PM
inside. remember, this is taken with the tire buried in the well.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487871
09/03/13 10:47 PM
09/03/13 10:47 PM
the front. I am planning on moving the Rear Axle back approximately 38mm.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487872
09/03/13 10:48 PM
09/03/13 10:48 PM
west palm beach, florida
modelmakerinc Offline
Before someone has to ask. They are 275-60-15 on ten inch torque thrust wheels.
and now they seem they will actually fit
Ricky did you get an approximate backspace to figure your rear axle width?
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
