Page 4 of 20 1 2 3 4 5 6 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487793
08/24/13 10:00 PM
08/24/13 10:00 PM
West Palm Beach, Florida
Copper Dart Offline OP
The other side..... is it easyer to see here?
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487794
08/24/13 10:02 PM
08/24/13 10:02 PM
any takers?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487795
08/25/13 12:49 AM
08/25/13 12:49 AM
That angle will decrease when the car is back on the ground, I thought the same thing when I installed my Alterkation unit. I would just trim the brace just enough to clear the control arm.JMO.
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: ] #1487796
08/25/13 09:08 AM
08/25/13 09:08 AM
I thought the same thing too but found out that the ball joint was installed upsidedown.
I will post some interesting pictures later.
Bet there's some that think me wrong!
Lord knows I've been wrong before! ( just a few times )
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487797
08/26/13 11:53 AM
08/26/13 11:53 AM
the picture shows the front suspension hanging at rest without the torsion bar installed. The upper Ball Joint has reached LOCK (cannot deflect any further) it's at a critical angle that should NEVER be even neared, much less reached in front end travel Lower Stop to Upper Stop.
I will post pictures as soon as I can get to my Home computer that has the pictures.
I dont think this is ever a problem with OEM "A" Arms because you would think it hard and/or impossible to install the ball joint from the wrong end.
I can only guess that thats why I got all the front end parts at such a GREAT deal!......
come to think of it..... that guy was selling me HIS (this front end just doesnt work ) Nightmare .
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487798
08/26/13 08:27 PM
08/26/13 08:27 PM
Remove Balljoint, Flip Arm, Reinstall Balljoint, Rinse and Repeat
Now look at the fully raised/extended angle of the balljoint.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487799
08/29/13 01:21 PM
08/29/13 01:21 PM
now that shes back on all four wheels i'm moving on to the subframe connectors, moving the springs inboard with a set of superstocks and mini tub'in it. All that needs to be completed before i can have a exhaust system custom fit.
i do have one dilemma with the cooling system i am juggling with.
I would rather run a 26" brass/copper 3 row radiator with a fan clutch and shroud than a Aluminum set-up with electric fans.
I'm looking at a Spectra CU332.
Haden 2765 fan clutch.
Am i heading down a dead end road?
Will it fit? Will it cool?
Fan shroud unavailable?
looks hoakie?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487800
08/29/13 09:03 PM
08/29/13 09:03 PM
More fun stuff from Mancini Racing
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487801
08/29/13 09:05 PM
08/29/13 09:05 PM
nudder
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487802
08/29/13 09:09 PM
08/29/13 09:09 PM
take a look at the trunk!
i'm going to cut THAT?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487803
08/29/13 09:14 PM
08/29/13 09:14 PM
i think i'm going to give the frame connectors a coat of rustolem before installing them
any ideas? i know i will have to clean where i will be welding but think protecting them with paint is a good idea. what say you?
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487804
08/31/13 01:43 AM
08/31/13 01:43 AM
Delray beach, Florida
P
Performance Only Offline
P
It looks like you've made some nice progress. No big deal cutting the trunk and tubs. Look at it this way, you'll just be correcting the factory engineering mistake. Any idea when you'll be done with the lift plate and dolly?
machine shop owner and engine builder
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Performance Only] #1487805
08/31/13 02:40 AM
08/31/13 02:40 AM
vashon island washington
hunterstroble Offline
The Metal chrome Mopar Performance steel valve covers clear nicely Because of the tapered edges. Our valve cover goes on and off easy.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Performance Only] #1487806
08/31/13 08:25 AM
08/31/13 08:25 AM
Done. I don't think I'll be pulling the engine out any time soon.
everything else goes smoothly.
I can drop them off or you are welcome to stop by.
Let me know what works best for you Dan.
Ricky
P.S. I might just have to change the Valve covers as suggested (thanks hunterstroble )to clear the A/ C blower motor. I don't want to spend allot of time modifying the HEVAC now. Too much to do.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487807
08/31/13 08:08 PM
08/31/13 08:08 PM
I didnt have to work today so I got to play!
Why does my back hurt so much? I am only playing
Test fitting the Frame connectors I decided it best to remove the stock fuel line. The lines are like new under the undercoating. It must have been applied on day one. The floors are in fantastic shape!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487808
08/31/13 08:17 PM
08/31/13 08:17 PM
you never know what you'll find when you begin taking things apart!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487809
08/31/13 08:20 PM
08/31/13 08:20 PM
that was under the drivers bench seat bottom.
Look what I found under the jute/carpet.
not that it means much, just kinda cool to have.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487810
08/31/13 08:22 PM
08/31/13 08:22 PM
how about those 40+ year old floors!
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487811
08/31/13 08:23 PM
08/31/13 08:23 PM
back floor too
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #1487812
08/31/13 08:30 PM
08/31/13 08:30 PM
Driver side frame rail need some modification before installing.
the parking brake cable crosses the frame rail so i made a tunnel
I read the front attachment point is not directly inline with the forward frame section. i going to fit them inline, kinda a slight angle looks better to me. pictures later.
Mom.
Ricky Valdes
