Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build
[Re: Copper Dart]
#1487793
08/24/13 10:00 PM
08/24/13 10:00 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
The other side..... is it easyer to see here?
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1487794
08/24/13 10:02 PM
08/24/13 10:02 PM
Copper Dart
any takers?
[Re: Copper Dart]
#1487795
08/25/13 12:49 AM
08/25/13 12:49 AM
That angle will decrease when the car is back on the ground, I thought the same thing when I installed my Alterkation unit. I would just trim the brace just enough to clear the control arm.JMO.
[Re: ]
#1487796
08/25/13 09:08 AM
08/25/13 09:08 AM
Copper Dart
I thought the same thing too but found out that the ball joint was installed upsidedown. I will post some interesting pictures later. Bet there's some that think me wrong! Lord knows I've been wrong before! ( just a few times )
[Re: Copper Dart]
#1487797
08/26/13 11:53 AM
08/26/13 11:53 AM
Copper Dart
[Re: Copper Dart]
#1487798
08/26/13 08:27 PM
08/26/13 08:27 PM
Copper Dart
Remove Balljoint, Flip Arm, Reinstall Balljoint, Rinse and Repeat Now look at the fully raised/extended angle of the balljoint.
[Re: Copper Dart]
#1487799
08/29/13 01:21 PM
08/29/13 01:21 PM
Copper Dart
now that shes back on all four wheels i'm moving on to the subframe connectors, moving the springs inboard with a set of superstocks and mini tub'in it. All that needs to be completed before i can have a exhaust system custom fit. i do have one dilemma with the cooling system i am juggling with. I would rather run a 26" brass/copper 3 row radiator with a fan clutch and shroud than a Aluminum set-up with electric fans. I'm looking at a Spectra CU332. Haden 2765 fan clutch. Am i heading down a dead end road? Will it fit? Will it cool? Fan shroud unavailable? looks hoakie?
[Re: Copper Dart]
#1487804
08/31/13 01:43 AM
08/31/13 01:43 AM
Posts: 2,091 Delray beach, Florida
Performance Only
It looks like you've made some nice progress. No big deal cutting the trunk and tubs. Look at it this way, you'll just be correcting the factory engineering mistake. Any idea when you'll be done with the lift plate and dolly?
machine shop owner and engine builder
[Re: Performance Only]
#1487805
08/31/13 02:40 AM
08/31/13 02:40 AM
Posts: 233 vashon island washington
hunterstroble
The Metal chrome Mopar Performance steel valve covers clear nicely Because of the tapered edges. Our valve cover goes on and off easy.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
[Re: Copper Dart]
#1487807
08/31/13 08:08 PM
08/31/13 08:08 PM
Copper Dart
I didnt have to work today so I got to play! Why does my back hurt so much? I am only playing Test fitting the Frame connectors I decided it best to remove the stock fuel line. The lines are like new under the undercoating. It must have been applied on day one. The floors are in fantastic shape!
[Re: Copper Dart]
#1487808
08/31/13 08:17 PM
08/31/13 08:17 PM
Copper Dart
you never know what you'll find when you begin taking things apart!
[Re: Copper Dart]
#1487809
08/31/13 08:20 PM
08/31/13 08:20 PM
Copper Dart
that was under the drivers bench seat bottom. Look what I found under the jute/carpet. not that it means much, just kinda cool to have.
