Retrosound speakers in E-body #1487416
08/20/13 03:26 PM
08/20/13 03:26 PM
NJ, USA
Flying Banana Offline OP
NJ, USA
Does anyone know if the Retrosound 3.5" and 4" X 10" speakers fit an E-body 3 speaker dash without dash-frame modification?
Re: Retrosound speakers in E-body [Re: Flying Banana] #1487417
08/20/13 06:05 PM
08/20/13 06:05 PM
Newtown, CT
70ucode Offline
70ucode  Offline
Newtown, CT
The 4x10 center speaker from Classic industries definitely does not fit. The magnet is way to big. You would have to cut the hole in the dash frame to fit it. I ended up sending my beat up torn original speaker out to be be re-coned.
John
Re: Retrosound speakers in E-body [Re: 70ucode] #1487418
08/20/13 09:58 PM
08/20/13 09:58 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
I used this company when ordering my speakers for my 71 challenger (single front speaker and single rear speaker).
http://www.turnswitch.com/speakers.htm
Re: Retrosound speakers in E-body [Re: JAK] #1487419
08/21/13 11:32 AM
08/21/13 11:32 AM
NJ, USA
NJ, USA
Those look nice, but I need 4 ohm speakers for my converted radio, and the Retrosound units have a dual coil center speaker that looks like it should work nicely if it fits without mods to the dash frame. Decent sound quality would also be a plus....
Re: Retrosound speakers in E-body [Re: Flying Banana] #1487420
08/22/13 12:57 AM
08/22/13 12:57 AM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Call them.
You'll need to wire in a resistor to make it a 4 ohm.
Outer small front corner speakers are clocked differently as far as the connectors go.
Re: Retrosound speakers in E-body [Re: Topcat] #1487421
08/22/13 04:13 AM
08/22/13 04:13 AM
Alabama
BigMoneyLewis Offline
Alabama
The FM conversions we do allow you to use 4 or 8 ohm speakers, however with 180 watts / 45 watts per channel , you are probably going to want speakers with a bit
more a$$ than factory replacements that were intended to handle a 2 1/2 or 5 watt radio originally.
Greg
gregward@mchsi.com phone 256-852-0955
