Can you change a 74 Barracuda Fr bumper into 72 style #1487229
08/20/13 03:26 AM
08/20/13 03:26 AM
NY
K
Killerinc Offline OP
K
NY
Can you change a 74 Barracuda front bumper into 72 style.
If so what do you need?
Re: Can you change a 74 Barracuda Fr bumper into 72 style [Re: Killerinc] #1487230
08/20/13 05:36 AM
08/20/13 05:36 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
if you have the brackets
Re: Can you change a 74 Barracuda Fr bumper into 72 style [Re: 05dakota] #1487231
08/20/13 09:47 AM
08/20/13 09:47 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
1. Remove the bumper with the brackets installed.
2. Remove the rubber filler strip that was used on the 73's and 74's.
3. Locate the "square" holes in the bumper brackets...forward of the slotted bumper mounting holes.
4. Drill out the "square" holes to 5/8". These now become your new mounting holes.
5. Remove the large bumper guards from the bumper and fill the hole with an extra chrome capped bumper bolt.
This mod will push the bumper in next to the body like the 70-72's.
Re: Can you change a 74 Barracuda Fr bumper into 72 style [Re: burdar] #1487232
08/20/13 04:32 PM
08/20/13 04:32 PM
NY
K
K
NY
Awesome thank you so much.
For the rear i bought the 72 brackets, do i need a 72 bumper?
or is there a trick for that?
Re: Can you change a 74 Barracuda Fr bumper into 72 style [Re: Killerinc] #1487233
08/21/13 10:55 AM
08/21/13 10:55 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You will just have to try the rear and see. The bolt holes might be in a different location.
Re: Can you change a 74 Barracuda Fr bumper into 72 style [Re: burdar] #1487234
08/21/13 11:52 AM
08/21/13 11:52 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
you will need the earlier bumper for the rear. The bolt holes do not line up.
Jason
