1 5/16 socket
#1487051
08/19/13 10:07 PM
08/19/13 10:07 PM
Posts: 4,066 Mo.
racerx
Mo.
Re: 1 5/16 socket
[Re: racerx]
#1487052
08/19/13 10:24 PM
08/19/13 10:24 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
I'm sure it will go once Seriously I have run facilities known as Auto Hobby Shops, a self and guided help garage if you will for the troops, in the Air Force for years and seen those larger Harbor Freight sockets used for much higher torque values than that over the years for FWD spindle nuts and Honda balancers with are at values in excess of 400ft/lbs without failure. IMO you will be fine.
Re: 1 5/16 socket
[Re: racerx]
#1487054
08/19/13 10:36 PM
08/19/13 10:36 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Can you grind the OD of the socket down to fit? I have a bunch of them like that for pinion work.
RIP Monte Smith
Re: 1 5/16 socket
[Re: qwkmopardan]
#1487060
08/20/13 11:35 AM
08/20/13 11:35 AM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I just went to the Granite City Oreillys and rented a 33mm, same as a 1-5/16, for $10. It was a nice HD impact socket so I did not take it back, just kept it and put it in the trailer tool box.
So there you have it ... when you need a tool, just go and steal it.
Re: 1 5/16 socket
[Re: qwkmopardan]
#1487062
08/20/13 02:33 PM
08/20/13 02:33 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Auto parts tool rentals are meant to be that way. Rent and return or keep it if you wish.
For some reason I don't think it's supposed to work that way. If it was $10 for the rental and a $40 deposit I'd agree.
Re: 1 5/16 socket
[Re: dogdays]
#1487064
08/20/13 03:04 PM
08/20/13 03:04 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep, thats the way it is around here too. You put down a deposit that is really the Value of the tool. Its a Free rental, but if you want it, you can keep it and they keep your payment.
They will tell you that right up front, Auto Zone, Oreilly, and Advanced auto, all have that policy here in Canton, Ohio.
Re: 1 5/16 socket
[Re: Thumperdart]
#1487067
08/20/13 06:46 PM
08/20/13 06:46 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Love the hate , guys. Love the hate. Or if I may paraphrase my late Father....." The three of youse....." I have a Craftsman in 1/2' drive that is much thinner than an impact socket......you can buy them one at a time in 6 or 12 point and they aren't all that expensive. Seems to me I got it after getting a 3/4 " drive with an adapter for something or other. Harley primary drive ?........but they didn't have the 1/2 " drive in stock at the time. I do have a couple 3/4" drive sockets for when I need to stand on the end of 6" of pipe to reach spec.
Re: 1 5/16 socket
[Re: justinp61]
#1487069
08/20/13 07:38 PM
08/20/13 07:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
1000%.. if you dont return the next person cant get it... I was gonna rent the cam bearing install kit from my local parts store... I had used it before and the last time the guy didnt return... they didnt want to replace the $200 kit
