Wipers go down instead of up #1485073
08/15/13 06:54 PM
08/15/13 06:54 PM
M.A.
Fern Offline OP
Fern  Offline OP
M.A.
When I turn my wipers on they go down instead of up. And when I turn them off they park at the top, so everything works, just backwards.
Is this a linkage problem?
Its a 3 speed motor on a 70 e body.
Re: Wipers go down instead of up [Re: Fern] #1485074
08/15/13 07:04 PM
08/15/13 07:04 PM
Newtown, CT
70ucode Offline
70ucode  Offline
Newtown, CT
Sounds like the linkage is connected to the motor wrong. Remove the top screen on the drivers side, remove the clip holding the linkage on (dont lose the washer) manually put the wipers parked, then connect the linkage and see if that solves it.
John
