Poly 318 Alt brackets same as LA engines ?
#1483488
08/12/13 08:21 PM
08/12/13 08:21 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
I know the style of the brackets changed but do they interchange from a Poly to a LA engine ?
So the bartender says to the horse " Gee, Why the long face?"
Re: Poly 318 Alt brackets same as LA engines ?
[Re: Andrewh]
#1483490
08/12/13 08:32 PM
08/12/13 08:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Obviously, the heads are different. So if the bracket bolts to the head, then no is probably the answer.
[Re: 1OFNONE]
#1483491
08/12/13 08:57 PM
08/12/13 08:57 PM
1OFNONE
Fort Morgan
Very good. Im going to swap a Denso alt onto my fathers Poly 318 and was just making sure. Thanks guys.
[Re: 1OFNONE]
#1483492
08/12/13 09:19 PM
08/12/13 09:19 PM
The 65 poly 318 and LA 273 used the same alternator bracket, but had two sets of mounting holes, one for the 318 poly head, and the other for the 273 wedge head. The 1965 A/LA bracket will also bolt to a later 318/340/360 LA. But since the later LA brackets don't have both an A and LA bolt pattern, I wouldn't think they would work on the poly without modification.
Now whether a Denso alternator would work with a poly alternator bracket, if that's what you're asking, can't say.
